help with sohc harness in 00 si
Old Apr 8, 2012 | 10:39 AM
lmndc4's Avatar
Default help with sohc harness in 00 si
so i bought a harness for a 00 si being told it was a si harness turns out it apears to be out of a sohc cuz the dizzy plug is different so my question is can i make it work and what is needed plase help!!!
Update******
alrite so I pluged everything up got the rywire dizzy adapter and I turn the ignition all acceseries work but wont crank. wtf
Plz help
Old Apr 8, 2012 | 02:34 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: help with sohc harness in 00 si
Make/model/year? Make it work with what engine? What ECU?
Old Apr 8, 2012 | 02:38 PM
Tw34k's Avatar
Dizzy plugs almost always change by OBD, not engine type. Is there only one plug or two?
Old Apr 8, 2012 | 02:43 PM
lmndc4's Avatar
00 si like stated 2000 honda civic si with b16 i bought a harness thinking it was out of a si but turns out to be a single cam vtec harness out of a 2000 civic ex so i wanna know what needs to be done for it to work cuz i noticed the distributor plug is diferent
Old Apr 8, 2012 | 02:44 PM
lmndc4's Avatar
Its one plug
Old Apr 8, 2012 | 03:48 PM
Tw34k's Avatar
Pictures would take all of the guess work out of this.
Old Apr 8, 2012 | 06:09 PM
mrsinger's Avatar
i am in the same boat with you, what i did was order a $35 adapter from rywire, like 8 pin to 10pin. From what I know they are pretty much interchangeable, but the IAT on mine is a bit different from the B series, so what you can do is find the pigtail (connector off a b series wiring harness) and wire it onto your new wiring harness so you can plug it right into the IAT sensor, which is on the intake arm..
so far those are the only two issues ive really had, if you have any you should message me because I would like to know somethings that could go wrong also.
Old Apr 8, 2012 | 06:11 PM
lmndc4's Avatar
I just wanna know if anyones used the single cam harness on a em1 and what they had to.do thats it
Old Apr 8, 2012 | 06:15 PM
lmndc4's Avatar
Yeah i ordered that harness already today just wanted to ask if any other plugs needed to be messed with or extended...so have u got urs running with that harness with no issues?
Old Apr 9, 2012 | 04:17 AM
mrsinger's Avatar
no i dont have it running yet, but everything plugs up correctly except for the two things i stated before, some people were telling me to extend the IAT wire but I didn't see a need in that because the harness is long enough as long as you get that pigtail..
Old Apr 9, 2012 | 04:47 AM
MonkeyMagic's Avatar
Google would take all of the guess work out of this.
fixed that for ya..
Old Apr 9, 2012 | 05:45 AM
kyden's Avatar
get the adapter harness, you'll have to get an IAT plug if you're using a b18/b20.
Old Apr 16, 2012 | 05:16 PM
lmndc4's Avatar
Update******
Plz help
teamrpm2
62
Jul 13, 2009 12:16 AM
jdmkevin
Jun 18, 2003 06:13 PM
