dohc cam gear settings discussion
Old Feb 28, 2012 | 11:54 AM
balbowskie's Avatar
Icon6 dohc cam gear settings discussion
Just wondering what others are running as cam gear settings on there dohc engines, weather there engine is turbo or naturally aspired. I am and know others who are interested in these settings and how there very in forced induction applications.
Old Feb 28, 2012 | 12:21 PM
Records's Avatar
Default Re: dohc cam gear settings discussion
I am interested in this matter too ^^
Old Feb 29, 2012 | 01:22 PM
balbowskie's Avatar
I just popped the hood on mine and I am running on exhaust cam retard 3 1/2 degs and advanced 2 1/2 degs on the intake. I am running rite now upgraded fuel system. Msd ignition, aem cold air, DC header. Borla 3" and sst Borla muffler, Etc....
Old Feb 29, 2012 | 04:01 PM
DraginX's Avatar
Every setup will be slightly different. If your head or block has been decked that changes things. Every aftermarket cam is different also. Best way to set them up is by degreeing them to the cam card specs before putting in the engine.
Old Mar 1, 2012 | 09:07 AM
balbowskie's Avatar
Yes this is very true, but what is your setup and settings, lets get some numbers and discuss why?
Old Mar 1, 2012 | 09:57 AM
kyden's Avatar
not sure what there is to discuss. degree settings are so different there's no 1 correct setting for everyone. only way to find out what works best for you is on the dyno.
Old Mar 1, 2012 | 01:24 PM
balbowskie's Avatar
If everyone's settings were the same it would not be much fun to discuss these settings. Yes dyno runs are the only way to find your settings and this thread should not be used in place of a dyno, maybe a baseline to start with at very most. If you would like to share your settings im open to discussion on this subject and why they work for your setup.
Old Mar 1, 2012 | 01:46 PM
grumblemarc's Avatar
The Grumpiest
This thread is pointless. Settings are made because they work. Period. They are different because no two setups are the same. Too many variables. Go talk to your local tuner if you need insight.
pureplayaz
21
Nov 16, 2008 02:11 PM
mattdenali
May 21, 2005 08:11 AM
mini-v-si
Mar 31, 2004 05:49 PM
livn2xlr8
Jun 30, 2003 09:54 PM
BeanRacer
Oct 16, 2001 09:28 PM
