rocker arm assembly
Old Apr 1, 2012 | 04:50 PM
sa2ms7on's Avatar
Default rocker arm assembly
I have a 96 accord ex 2.2 vtec. I just replaced the LMAs but didnt have a torque wrench when putting the rocker arm assembly back on to the motor so i just guesstimated it. When readjusting the valves they were all really tight; meaning I tightened the rocker arm assembly tighter than it was before. I just readjusted the valves to the correct measurements and it runs great but the idle dropped way low. I just raised up the idle to the correct specs with the screw. Everything is fine but I have always heard not to mess with the factory idle setting. My question is will tightening the rocker arm assembly too tight effect anything negatively?
Old Apr 1, 2012 | 06:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: rocker arm assembly
Over-torquing or under-torquing will have a negative effect, how much of an effect will depend on how much over/under you are. 94
Old Apr 1, 2012 | 07:00 PM
sa2ms7on's Avatar
Its not by much. I only had to loosen the valves ever so slightly. What negative effect will it have? Possibly damaging lobes?
javierasous
18
Oct 3, 2008 06:15 AM
music462
Apr 6, 2008 12:55 PM
b20integrapower
Feb 1, 2006 06:07 PM
Hondapreludeg
Nov 23, 2005 05:03 PM
Rywire
10
Mar 4, 2003 03:14 PM
