chirpping from the 98 si
Old Mar 1, 2012 | 02:59 PM
userjh5174's Avatar
Default chirpping from the 98 si
Hi guys,
New to this site and I have a question to ask.
I have a little chirpping/tapping from my throw out bearing fork. It goes away after I spray some lube using a straw inside the area, but it comes back after about two days.
Does anyone know of a quick fix solution for this? It seems that the lube used on the little pivot ball wears off or something, I guess.
Old Mar 1, 2012 | 03:08 PM
eg6 type-R's Avatar
Default Re: chirpping from the 98 si
pull the tranny off and check if the throw out bearing still has grease or if its dried.. that might be causing your problem
Old Mar 5, 2012 | 03:52 AM
userjh5174's Avatar
Thanks for the advise.
lv6l
May 14, 2010 09:22 AM
tdrolin123
Transmission & Drivetrain
Oct 17, 2008 10:09 PM
citrus3000psi
Jan 3, 2008 10:28 AM
user 996328629
May 18, 2003 05:26 PM
