Intermittent no start
Old Mar 23, 2012 | 07:18 PM
salaamq's Avatar
Default Intermittent no start
My del sol has an issue where now and then it won't start when it's been running for a bit. Like the other day I went to the gas station, filled up, and it wouldn't start. It seemed like it would fire a few times and then die. I turned the ignition off and waited a minute, and it started right up. Its not the first time I've had this problem, but it only happens every now and then. Any ideas?
Old Mar 25, 2012 | 10:04 AM
fcm's Avatar
fcm
Old Fart
Default Re: Intermittent no start
most common problem is the PGM-FI Main Relay... http://techauto.awardspace.com/mainrelay.html
It is what I would check/fix first. 94
Old Mar 26, 2012 | 10:06 AM
salaamq's Avatar
I took out the main relay. Wow, what a pain to get to. Anyways, there looks to be 1 cracked solder joint. Ill repair that and see what happens.
I also found that there is a small switch under my steering column and its hooked up to a small box under the dash. Alarm system maybe? When I flip the switch, nothing happens. There's also a small light on the top of the steering column.
joshsdelslow
Sep 2, 2011 04:46 PM
nismogrendel
Apr 24, 2010 01:43 AM
treborpaul
Oct 24, 2008 01:32 PM
g-ride-si
Jan 13, 2006 08:14 AM
jdmkrazie
Jun 16, 2004 08:42 AM
