Engine urethane mounts
Old Apr 2, 2012 | 08:22 PM
Elias-Kiev's Avatar
Default Engine urethane mounts
Hello guys. help me with some info.
What usual outside diameter of polyurethane engine mount bushings (like Hasport) for street use? So it won't be too stiff for daily use?
thanks!
I'm talking about BARREL O.D. on this pic:
Old Apr 3, 2012 | 09:41 AM
Hasport's Avatar
Default Re: Engine urethane mounts
you would want to use the u62a street urethane for street use
Old Apr 3, 2012 | 10:04 PM
Elias-Kiev's Avatar
yap. But what diameter you usually use for mounts?
thanks!
Old Apr 5, 2012 | 01:25 PM
Hasport's Avatar
if you are buying hasport mounts why does it matter what the diameter is?
Old Apr 5, 2012 | 10:14 PM
Robinsoneion's Avatar
One of the biggest problems in most cars is soggy motor mounts. This could be caused by torn or damaged motor mounts or they are just too soft. This can result in a few different problems. In the case of rod shifter manual transmissions, (up to 6g civics and 3g Integras) soggy motor mounts can lead to quite a bit of shifter movement. This problem alone isn't that bad.
Old Apr 9, 2012 | 10:34 AM
Elias-Kiev's Avatar
Old Apr 9, 2012 | 10:49 AM
Hasport's Avatar
are you trying to make your own mounts?
cant find urethane so you just want to buy Hasport urethane to put in?
why do you need Hasport urethane specs?
alx_90ef
20
May 30, 2014 06:31 AM
white_db8
May 26, 2007 09:34 AM
Slowass4dr
16
Aug 12, 2005 06:51 PM
Drew Peacock
Dec 3, 2004 03:31 PM
01gizzer
May 30, 2002 11:56 PM
