map sensor voltage?
Old Apr 13, 2012 | 09:40 PM
Charlie Moua's Avatar
Default map sensor voltage?
Q:
what should be the voltage of the wires going to the MAP sensor on the PLUG side?
what should be the voltage of the MAP wires leading into the ECU?
D17 & D19 slot
http://technet.ff-squad.com/wiring.obd1.htm
Old Apr 13, 2012 | 10:06 PM
hybridmiklo's Avatar
Default Re: map sensor voltage?
The reference should be 5volts. The signal will depend on manifold vacuum and elevation.
Old Apr 13, 2012 | 11:31 PM
turbohatch96y7's Avatar
D19 should be 5 volts
You could bench test is with a vacume pump. And watch the voltage sweep.
With anolog meter or digital meter.
Old Apr 18, 2012 | 07:57 PM
i just decided to run the 3 wires from map sensor to the ECU....
i figured there must of been a short somewhere.
NO more code 3 BUT car does have slight backfire at idel.... just not when you rev it.
Still running rich.
I'm going to try new ecu
Veggie Man
Sep 25, 2012 02:49 PM
Charlie Moua
Apr 18, 2012 07:57 PM
msinsky14
Nov 25, 2008 05:57 PM
hondaeg8
Jun 22, 2005 03:03 PM
