N/A car with Turbo Muffler
Old Apr 16, 2012 | 08:31 PM
Freckles's Avatar
Default N/A car with Turbo Muffler
I have a 92 civic hatchback.. Getting tanabe exhaust from a friend for like pretty much free. http://www.suprastore.com/tangpowmed.html
I was wondering how it would sound with 2.25 piping on a B series. The inlet is 3 inches, but I've heard that muffler shops can make adapters and ****.. I just want to know how it sounds. I don't believe in back pressure or none of that **** so that's not relevant.
Old Apr 16, 2012 | 08:46 PM
deving916's Avatar
Default Re: N/A car with Turbo Muffler
how are we going to tell you how it sounds over a forum?
look up sound clips
Old Apr 16, 2012 | 09:34 PM
Arthas's Avatar
Its going to sound like this..
You ready???
vroooooooooooooom vrooooooooooooooooooooooooooooom vrooooooooooooooooooooooooooooooooooooom
Then once you hit the highway its going to sound like this.
vroooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo om.
Old Apr 16, 2012 | 10:48 PM
Freckles's Avatar
I'm asking if a turbo muffler on a N/A car would sound raspy, deep, low. I'm pretty sure you can use adjectives, and not be smartasses.
Old Apr 16, 2012 | 10:56 PM
jbpnoman's Avatar
Every muffler sounds different on every setup, and we have absolutely no way of telling you how it's going to sound on your car. Bolt it up and see what happens, or get to searching on YouTube for a similar setup. I had to go through 4 different mufflers before I found one I was happy with.
Old Apr 17, 2012 | 02:15 AM
Libertariat's Avatar
Ek Forever y0!
A "turbo muffler" is awfully subjective to the manufacturer. Usually they're chambered for some reason.
Typically they're quieter.
Old Apr 17, 2012 | 06:58 AM
tjus3130's Avatar
IMO you deff don't need to go bigger then 2.25 on a non turbo car. And there right, Moines gonna be able to tell you the exact sound as every set up is different. I'd look up sound clips of the muffler and start from there. Plus there's a nifty lil thing called YouTube :$
Old Apr 17, 2012 | 07:18 AM
Red_Army's Avatar
3 in all the way around.
regardless of what anyone tries to tell you 3 in is better. from stock D to fully built K.
but you got the exhaust system so isn't that all piping and the muffler? or are you just getting the muffler?
Old Apr 17, 2012 | 07:21 AM
Miami Honda's Avatar
wow dont spread misinformation guy. On a n/a engine he will actually lose hp with a 3inch pipe my friend.
Old Apr 17, 2012 | 07:37 AM
Ek Forever y0!
Disagree all you want, you're wrong, There's no such thing really as "too big". Every dyno I've seen has proven that even on d16's and b16's the 3" exhaust will make more power all across the RPM band. 2-5whp on most cars.
The "needs backpressure" thing is a myth. Well, until we're talking about 6" diameter exhausts.
2.5" is plenty for most cars, since as you go larger you really start paying for the small amount of benefit with a LOT of decibels.
Like I said, disagree all you want:
http://www.hondacivicforum.com/forum...ts-wrong-3064/
Here's a dyno:
2.5" vs 3" discussion
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/there-point-3%22-exhaust-becomes-ok-n-build-b20-2298917/
3" on stock motor showed big gains
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/3%22-catback-exhaust-stock-jdm-h22a-dyno-2197695/
Originally Posted by Bisimoto
I am not surprised. I ran 3" exhaust piping on my D16A6 years ago on the street, and saw great gains then!
Originally Posted by davinadze
I had a 2.36" apexi on my b16a. And it was way louder then my 3" full vibrant exhaust. And 3" pulls allot better everywhere across the board. I tryed 2.36 a couple of years later, but took it off, and put the old 3" back on... way more power!!!
Originally Posted by 00Red_SiR
In a nut shell I haven't ever seen a dyno on here that I can recall, where a 3" exhaust made less power than a 2.5" on any setup. If you're really serious about this, do some searching, limiting the parameters so you get more specific information. The next step would be to dyno each exhaust on your car and report back as to what worked best for you, then sell the one you don't want.
Originally Posted by 2LEM1
both me and 00Red_Sir are saying that a 3" exhaust will make more power on almost every setup. I have never, ever seen a dyno to show a loss of HP going from 2.5 to 3" exhaust.
From what I understand everything past your header is just restriction.
Backpressure theory:
http://www.automotiveforums.com/vbul...ad.php?t=13199
Integra Type-R's had 2.5" piping from the factory. So how can 3" just be plain too big?
Is there some visceral cliff your engine walks off of with the extra .5"?
You're wrong, get over it. I thought the same thing for years.
Old Apr 17, 2012 | 09:03 PM
Freckles's Avatar
Finally someone with no smartass comment. Thanks dude.
javon972
Jun 4, 2008 06:19 PM
91civicmaine
Mar 2, 2006 12:13 PM
Meet07
Feb 15, 2006 06:58 AM
wilslude92
Sep 21, 2003 01:35 PM
SmokyMtnRex
Jun 23, 2002 07:53 PM
