Turning headlights on makes wipers come on???????
Old Mar 17, 2012 | 07:36 AM
uvamosk's Avatar
Default Turning headlights on makes wipers come on???????
Well, I did a engine swap on my civic and at the same type swapped over to a domani front end.
everything has worked fine for months then one day when I turned my headlights on the wipers just came on. They would go back and forth a few times then shut off.
Well, I figured out its all associated with my driver head light. When I turn the wipers on the driver headlight dims and when the wipers quit the head light goes to its normal brightness.
now for the best part, if I get out of the car and hit the headlight it will go bright and the wipers stop..
I swapped a new bulb in and it still does it. I checked the plug and wires and they look good.
Im so confused.. Does anyone know what it could be?
Another thing that is odd is If i hold the brights on for a few then turn the headlights on like normal they wipers wont come on most of the time. This started making me think it was something ground/heat related.
Old Mar 17, 2012 | 02:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: Turning headlights on makes wipers come on???????
When one circuit, [head light] has an effect on another circuit, [wipers] it is almost always due to a grounding problem, check the ground for the head light. 94
Old Mar 18, 2012 | 01:51 PM
uvamosk's Avatar
I'll give it ago read somewhere that someone had the same problem same year car and was told to check ground and they never posted again so maybe it fixed it.
I was also under the dash doing stuff for my swap so maybe did something.
landon.alder
Nov 20, 2009 08:02 AM
Jenkinsal2
Sep 19, 2009 09:55 AM
gfunkmos37
Jan 26, 2005 09:35 AM
civicboy95
Aug 4, 2002 05:40 PM
