Help me Honda heads
Old Apr 2, 2012 | 11:41 AM
TaraDa5's Avatar
Default Help me Honda heads
Ok guys and gals,
Story is I have a da5 teg, the head gasket went, got it replaced, went again 2 weeks later, so we stripped it bare and sent it to get pressure tested, came back ok but it needs a bore and hone, can get this done no bother just can't find oversized pistons for it, it's a zc coded engine 1.6 sohc non v-tec but still injection, most zc were dual carb, can anybody tell me where to get pistons??
Thanks
Tara
Do not tell me to buy a new engine or put in a tec.. I want to rebuild my engine
Old Apr 2, 2012 | 12:09 PM
TaraDa5's Avatar
Default Re: Help me Honda heads
Anybody have a clue no??
Old Apr 2, 2012 | 12:36 PM
TaraDa5's Avatar
506,557 members and nobody can help.
Old Apr 2, 2012 | 12:50 PM
TaraDa5's Avatar
Stop licking windows and help me
Old Apr 2, 2012 | 09:50 PM
EM2abe's Avatar
sorry dude..... did you try googling it?
Old Apr 3, 2012 | 03:51 AM
94EG8's Avatar
Seagull Management
What's the current piston code? PM3? '92 - '95 D15B7 pistons should be the same.
Old Apr 24, 2012 | 08:00 PM
KristianGunther's Avatar
Hey i have a question that i cant seem to get an answer for and im new to this site so i really dont know where i should write this but i guess this would be okay.
Well earlier today i was taking apart my B18c1 shortblock i purchased and everything seems to be in really good shape...but after taking it all apart i realized that i had forgotten to number the connecting rods all the caps are on the right rods but...i didnt mark them, the have numbers on them, three of the rods have the number 3 on them and one of them has the number 2 on it. i was told that the rods all need to go back in there original place, all the journals look mint and everything can i just put the rods anywhere or can i find out which rod is which? can someone help me out???? im new to this site so if anything Email me at Crxkid@ymail.com or pm an ill give you my number thank you
Old Apr 24, 2012 | 09:07 PM
JustOneOrTwoPosts's Avatar
since they are out of order, you should put them in one by one and measure the clearances(plastigauge) and see if they are within specs. From there, you could place the correct rods in the correct cylinder based on the oem specs. good luck.
Old Apr 27, 2012 | 08:49 PM
Tim1982's Avatar
Swap it with a b18c type r engine.
bryand130
Apr 8, 2014 12:55 PM
civicxxman
Apr 24, 2008 02:15 PM
DOHClessEF-9
Jan 28, 2005 12:01 PM
djnikko
Oct 24, 2003 12:47 PM
crxnug
Nov 29, 2001 12:42 PM
