Jackstand high or low for safety?
Old Mar 14, 2012 | 08:57 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Jackstand high or low for safety?
My jack stands are pretty high that when I rest the car on top, it's high enough for me to do what I need to do. See line B.
I was just thinking, and reading on the proper use of the the jackstand, it always say to adjust it to the height I need. Meaning set the stand on one of the notches. See line A. Meaning set it to whatever height the user need.
So my question is, is there any risk by using the stands at the "default height" setting? When you think about it, it is resting on the U section.
Or is it better to be on one of the notches, even if it's the lowest? Life the car higher than what I need.
Or makes no difference?
Old Mar 14, 2012 | 09:49 AM
GagnarTheUnruly's Avatar
Default Re: Jackstand high or low for safety?
As long as the floor is flat (and the jacks are even) you should be safe at any setting. But to be extra cautious put some spare wheels under the car in an area you aren't working. That way if something terrible does happen the car will land on the wheels and not you.
Old Mar 14, 2012 | 10:25 PM
fcm's Avatar
fcm
Old Fart
Like a ladder avoid using the last rungs, otherwize as mentioned, leval floor and soildly positioned jack stands, the spare tire is also a good idea.94
Old Mar 15, 2012 | 06:13 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Second that. I rarely (if ever) work at home anymore,but I always make sure to put a tire under the car for insurance.
Old Mar 16, 2012 | 06:56 PM
uberEFtuner's Avatar
When I put off my car on jack stands I always shake the car. This is to make sure the jack stands are solid before I get under.
The smaller and cheaper jack stands are less stable than larger ones, like 3 ton.
05civicdriver
Honda Civic (2001 - 2005)
11
Feb 20, 2008 08:34 PM
chibiko
Apr 25, 2007 12:31 PM
StreetRacinThug
Dec 21, 2005 06:20 PM
Paprika
Sep 12, 2004 06:23 PM
Pompiuses
Sep 11, 2004 03:38 AM
