radiator fan wiring
Old Feb 28, 2012 | 07:46 AM
hmongxcuz's Avatar
Default radiator fan wiring
could someone explain to me how to wire my radiator fan to stay on when i turn on my car?
my sensor broked, the one next to the t-stat housing.
Old Feb 28, 2012 | 08:48 AM
grumblemarc's Avatar
The Grumpiest
Default Re: radiator fan wiring
Replace the sensor. It's not that expensive.
Old Feb 28, 2012 | 10:55 AM
civickiller's Avatar
connect the 2 wires for the sensor together
Old Feb 28, 2012 | 05:43 PM
hmongxcuz's Avatar
so cut the clip and just wire the 2 wires together??
Old Feb 28, 2012 | 05:44 PM
hmongxcuz's Avatar
ill look into how much it is
Old Feb 28, 2012 | 05:55 PM
turbohatch96y7's Avatar
Splicing the 2 wires together will provide a constant ground to your radiator fan relay coil, closing the relay tips providing a POSITVE 12 volts to your radiator fan.
Down side to this is your fan will always be on with the key on.
Or you can make a switch either to the coil or to the positive side to your fan. Either way is not right but will work.
If you do jump the connector you could just put a ring terminal to the green wire and ground that wire. The same as splicing the blk and grn together.
Old Feb 28, 2012 | 05:58 PM
yes but ideally you just want to change the sensor.
if you do cut it, leave enough wire to reconnect it you can
Old Feb 28, 2012 | 07:40 PM
seanbev24's Avatar
Just buy the damn sensor. If it was good to run the fan all the time, Honda wouldn't waste the money installing temperature switches and fan relays.
Old Feb 29, 2012 | 07:08 AM
tron_'s Avatar
10 Year Member
If your fan is constantly on, you will limit airflow going through the radiator at high speeds (ie highway speeds). Just replace the sensor like multiple people have said.
Old Feb 29, 2012 | 07:45 AM
mKepolas's Avatar
Don't Cut your wire. If you need a temporary fix until you can buy a new fan switch, just take a paperclip or any other piece of metal that will fit and jump the connector.
Old Feb 29, 2012 | 04:24 PM
hmongxcuz's Avatar
ok guys im gonna paper clip it till i get a new one. not gonna cut anything.
ty for the info
dooma
Feb 5, 2013 04:31 PM
maverick32
Jun 17, 2009 10:49 PM
creepy116
18
Dec 15, 2007 11:15 AM
SexyAzNMami
Dec 10, 2004 09:39 PM
