Head milled 35thou,which head gasket????
Old Mar 18, 2003 | 02:22 AM
J2turbo21's Avatar
Default Head milled 35thou,which head gasket????
The head i just bought has been milled 35thou so what head gasket should i get and is there stuff i should worry about?
Old Mar 18, 2003 | 06:30 AM
splitime's Avatar
Default Re: Head milled 35thou,which head gasket???? (J2turbo21)
Thats quite a bit of milling, i'd get an oem headgasket. Then attach the head and clay for clearance.
Old Mar 18, 2003 | 09:15 AM
Shark Tank's Avatar
Default Re: Head milled 35thou,which head gasket???? (splitime)
stock you jackass...j/k...why did they take 35 thousandths off?
[Modified by CART fan, 1:15 PM 3/18/2003]
Old Mar 18, 2003 | 01:25 PM
J2turbo21's Avatar
Default Re: Head milled 35thou,which head gasket???? (Shark Tank)
I dont know thats how i bought it.
Old Mar 18, 2003 | 01:35 PM
Katman's Avatar
35/1000's isn't a super duper crazy mill job, closer to 40/1000+ is though.
Stock/OEM should be your main choice of headgasket though.
(if you haven't yet) You should look into getting some adjustable camsprockets to correct the cam timing once you put that milled head on your block.
Old Mar 18, 2003 | 02:08 PM
6ghatch's Avatar
Does anyone know how much milling your head will affect cam timing?
Example: For every 10 thousandths off the head your cams will need to be advanced ??? degrees.
Old Mar 18, 2003 | 02:37 PM
SanoJDm's Avatar
Default Re: Head milled 35thou,which head gasket???? (6ghatch)
my machcine shop teacher says that every 10/1000 will affect timing about 1 degree. also forevery 10/1000 it should raise compression almost 10psi on a compression test.
[Modified by SanoJDm, 3:38 PM 3/18/2003]
Old Mar 18, 2003 | 05:56 PM
J2turbo21's Avatar
Default Re: Head milled 35thou,which head gasket???? (SanoJDm)
Well milling will affect my compression so should i get a thicker gasket so that the c/r wont go up?
Old Mar 18, 2003 | 07:22 PM
SanoJDm's Avatar
just get a Honda OEM spec one. the raise in compression ration will most likely not make that much of a difference. I would not worry about detonation either.
Old Mar 18, 2003 | 08:41 PM
J2turbo21's Avatar
This guy on HT i forgot his name said if the motor has 11.5c/r pistons with a stock head,with my head it should be well over the 13.0c/r.
Old Mar 18, 2003 | 09:39 PM
aut0tek's Avatar
No... my head is a b16a head and I have the JE 5.7 dome pistons and a Cometic .067" gasket... If you're worried about it, talk to cometic. they'll make u a fat-*** gasket if u really want it.
Harry
Old Mar 19, 2003 | 05:39 AM
Soundwave9900's Avatar
go no head gasket
TURBL0W
Feb 9, 2006 09:02 PM
donnjuan2point2
Sep 16, 2003 10:08 AM
donnjuan2point2
Sep 16, 2003 09:18 AM
NateTEG95
Apr 27, 2003 05:41 PM
