OBD2 version 2 p72 HELP ME intake manifold
Can someone please help me? I have a 2001GSR to make a long story short. I miss-shifted, and bent valves. Got it fixed, but when i got it fixed I put a Skunk2 intake manifold. 2 days later. Check engine light goes on. Its code #9? i think that is a CYP sensor? i checked all the connectors to that sensor and everything is fine. I know on GSR manifolds there is 2 butterflies and the skunk 2 manifold there is only 1. what caused that damm number 9? I just bought a p73 (98spec ITR ECU) will this fix my problem? If it does i still need to get a wire harness to convert my OBD2 VERSION2 to a OBD2 VERSION1, because that damm ECU is still 98. I dont know what to do. can someone give me some advice please?
if you are smokin pass it this way y0
the skunk2 manifold has a single stage setup. no butterflys man. GSR has 4, count em 1 per cylinder. just thought I would be picky and point that out
miguel329
Jan 27, 2008 09:25 PM
