To members with SMSP cat. converter...
Old Mar 19, 2003 | 06:36 PM
SSBP DC2's Avatar
Default To members with SMSP cat. converter...
could you do me a favor and take a picture of the inlet or outlet of the cat with a ruler held up to measure the diameter? could you also list what is the advertised diameter of the cat. thank you in advance. -demitri
Old Mar 19, 2003 | 07:52 PM
Padawan's Avatar
Darth ModerVader
Default Re: To members with SMSP cat. converter... (SSBP DC2)
Do you mean the inner diameter of the flange opening? If so, I believe it is 2.5" inner diameter. Contact Dave himself and I'm sure he will be more than happy to answer any questions.
Old Mar 19, 2003 | 08:12 PM
SSBP DC2's Avatar
Default Re: To members with SMSP cat. converter... (Padawan)
i've always thought it was 2.5 outter, if it's really that then i have to get the 2.25 inner...does anyone have pics? measurements?
Old Mar 19, 2003 | 08:34 PM
Padawan's Avatar
Darth ModerVader
As I said, Dave has more experience with Carsound cats. than anyone I can think of, and will have no problem answering all of your questions. I'm quite certain that the flange is 2.5" ID, because he tapers his cat-backs' B-pipe flanges to eliminate the mismatch between the cat's 2.5" ID outlet and the 2.5" OD tubing used on the cat-back. Still, why not just ask him anything you still need answered?
EDIT: It didn't occur to me that you might not realize that Dave Stadulis is the owner of SMSP.
[Modified by Padawan, 12:37 AM 3/20/2003]
Old Mar 19, 2003 | 08:41 PM
SSBP DC2's Avatar
okay thanks i will contact him
Old Mar 25, 2003 | 12:11 AM
SMSP's Avatar
The 2-1/2" universal cats are measured as the ID. This is so the muffler shops can just slide the tubing in each end and weld them up. For my 2-1/2 cats. I use a short piece of 2.50" OD x .071" wall 409 sst and flare it for the donut. So the ID of the inlet shouldbe around 2.36". On the outlet side, the 3 bolt flange slides over the tubing so the ID is 2.50" +. This is why I do a taper flare on my B pipes so they will be at least 2.50" ID at the inlet and there will be no mismatch.
Old Mar 25, 2003 | 01:50 AM
SlayANT's Avatar
Default Re: To members with SMSP cat. converter... (SMSP)
Pix you requested:
to Dave.
Edit: If anyone is wondering, IT ISN'T RUSTED!
[Modified by SlayANT, 2:55 AM 3/25/2003]
silentkill03
Nov 9, 2004 02:28 PM
slowacura
Oct 13, 2002 07:30 AM
Stewie
Aug 20, 2002 05:50 AM
citanest
Mar 7, 2002 10:52 AM
