Crazy Idea..........Turbo Questions.............
Old Mar 20, 2003 | 07:10 PM
Fa-Q Racing's Avatar
Default Crazy Idea..........Turbo Questions.............
My work has a junked 1984 Nissan pulsar Turbo.......would it be possible to put this turbo on a 1984 CRX?
Crazy Idea I know, but the turbo would be free if it works.......Let me know....
Old Mar 20, 2003 | 07:17 PM
dfoxengr's Avatar
Default Re: Crazy Idea..........Turbo Questions............. (Fa-qracing1991)
you can put basically any turbo on anything...basically...
thats called junkyard turbo setup, will work just need to make custom piping and manifold etc.
Old Mar 20, 2003 | 10:14 PM
MikeMAN's Avatar
Default Re: Crazy Idea..........Turbo Questions............. (hybridvteceg)
with patience and some $$ u can do ANYTHING, but junkyard turbos are pretty easy to do....search around here. Lots of info.
Good luck if you decide to do it!
mike
Old Mar 28, 2003 | 10:47 AM
Default Re: Crazy Idea..........Turbo Questions............. (MikeMAN)
Thanks for your help, but I heard that turbos are hard to take care of......will they beat up engines? Cut their life span?
Old Mar 28, 2003 | 11:34 AM
B16Ej1's Avatar
i am also thinking of doing a homemade turbo setup, but as you just said, i have heard rumors that turbos are high maintanance, if i can get an honest answer, it might help me decide on FI or N/A
Old Mar 28, 2003 | 11:46 AM
2muchPSI's Avatar
Default Re: Crazy Idea..........Turbo Questions............. (cream)
yes, they are high maintenance.
Old Mar 28, 2003 | 11:49 AM
arsenaldragster's Avatar
Well turbo requires a little more attention to your motor. You need to keep up on the oil changes and regular maintenance. It does take some time and money.. but you will be very happy with a turbo motor.. believe me ive seen it many times.. but like i said it takes time.. you need to gather the right parts.. i.e turbo, wastegate, manifold, piping, intercooler, fmu.. etc... good luck.. let us know how it goes
Old Mar 29, 2003 | 12:16 PM
Draco's Avatar
Anything that puts more power into an engine will decrease the life, but the torque is worth it I think. Remember that the most important part of a turbo system is the fuel management. Putting the right amount of fuel witht he right amount of air will prevent knock (detonation), which is what will bring the life of your engine to a very quick end.
P.S. To learn everythig you ever wanted to know about turbos, read Corky bell's book, <U>Maximum Boost</U>
[Modified by Draco, 9:18 PM 3/29/2003]
stknfghtr1
Aug 3, 2011 06:21 PM
eglslsd
Jun 6, 2007 06:36 PM
1000kg88hb
Mar 12, 2007 01:01 PM
RACINTWEEK
Dec 30, 2004 12:57 PM
sohcvtec1995
Sep 16, 2003 12:05 PM
