Bolts for Engine Stand
Old Mar 18, 2003 | 12:28 PM
Mr. Thunderlips's Avatar
Default Bolts for Engine Stand
I have searched under this topic to produce mediocre results...I have learned a 12mm extra fine thread bolt will fit...But where to find these is another question. I spent my entire Saturday driving all over my town...Any help would be very appreciated.
Old Mar 18, 2003 | 01:42 PM
Default Re: Bolts for Engine Stand (ThunderLips)
Someone please help...
Old Mar 18, 2003 | 02:00 PM
IN VTEC's Avatar
Local hardware store.
12x1.25 (thread pitch) for the very top holes.
length....probably around 70mm or 80mm
And then getting a really long bolt with nut and washers for the very bottom holes (no threads).
If you can't find anything for the top holes, I can get them for you...I've found my local hardware store that meets all my needs.
Old Mar 18, 2003 | 02:08 PM
Default Re: Bolts for Engine Stand (IN VTEC)
Honestly, I have gone everwhere around here...Home Depot, Do It Center, Lowes...Even tried Pep-Boys and PAW. Found the right threads...But not length.
If you could get the bolts, I'd send you some cash yO!
Old Mar 18, 2003 | 02:36 PM
Sonny's Avatar
25 Year Member
Goto the local junkyard. You'll be tripping over them.
Sonny
Old Mar 18, 2003 | 02:38 PM
Default Re: Bolts for Engine Stand (PIMPASSBEOTCH)
Napa is the one place I didn't think of...
Now before I go back, does anyone know the EXACT specs I need? So I don't walk in and mutter off random bullshit?
Old Mar 18, 2003 | 04:53 PM
IN VTEC's Avatar
I think I'd actually try 95mm or 100mm length instead of 80mm (3" just doesn't seem like enough).
I know that the bolts used for the front LCA shock forks are just right in length. So if you can crawl under the car and take a quick measurement, that should tell you how long.
Old Mar 18, 2003 | 05:01 PM
BabyDaddy's Avatar
is this motor's tranny mounting bolts too short to use? i'm confused.
Old Mar 18, 2003 | 11:58 PM
Default Re: Bolts for Engine Stand (BabyDaddy)
Tranny bolts too short...Yes.
Old Mar 19, 2003 | 04:54 AM
IN VTEC's Avatar
Can you get me a quick measure of the engine stand's lengths? It'll make getting the bolts a lot easier and accurate. Your stand might be a little different.
Old Mar 19, 2003 | 06:04 AM
94CivicSi's Avatar
I cut about 1/2" of material off the arms on the engine stand and then I was able to attach it with the tranny bolts. Hack saw + 5 minutes and you're done. Sounds ghetto, but like you, I can't find a source for fine metric hardware anywhere near me . After 2 weeks of looking for these stupid bolts, I just wanted to get started o the damn motor.
Oh, and for the lowers, you can use just about bolt since the holes are not threaded. I used long SAE carriage bolts with big flat washers on both sides of the block.
Old Mar 19, 2003 | 06:34 AM
RCautoworks's Avatar
Default Re: Bolts for Engine Stand (94CivicSi)
Goto home depot and get a big bolt rod or what ever its called. Its just like a rod with threads. Get the right thread and pitch and cut it the right length. Then get some nuts to fit over it. Thats what I did for the bottom hole that goes all the way threw.
Old Mar 19, 2003 | 09:30 AM
Everything accounted for those little arms are exactly 2 inches long. That includes going all the way through.
Old Mar 20, 2003 | 12:52 PM
Anyone with some light?
Old Mar 20, 2003 | 12:54 PM
BabyDaddy's Avatar
That "cutting the stand's sleeves shorter" sounds like a winner to me.
Old Mar 20, 2003 | 01:17 PM
Ok, I cant cut what is already 2 inches long...That's just not enough support. And besides I don't have tranny bolts lying around anywhere. I have a block...That's it.
Old Mar 20, 2003 | 01:23 PM
I don't know, unless you have a different stand then me. I have thoughs arms to and the bolts from the tranny worked fine for me.
Old Mar 20, 2003 | 02:21 PM
RAWB's Avatar
So these are the ones you need then, right?
[Modified by RAWB, 3:22 PM 3/20/2003]
Old Mar 20, 2003 | 04:45 PM
Default Re: Bolts for Engine Stand (RAWB)
I found them today...Jesus. Took only three days.
Thanks for all your help guys.
Old Mar 20, 2003 | 10:14 PM
RAWB's Avatar
Where did you finally get em???
Old Mar 20, 2003 | 10:18 PM
Smaller hardware store by my house...I overlooked it earlier.
GSRCRXsi
Welding / Fabrication
Jul 27, 2006 04:34 AM
80884
19
May 10, 2005 02:17 PM
Catch 22
Jan 9, 2005 05:05 PM
Matgallis
Aug 25, 2004 02:36 PM
93preludes
Jan 5, 2003 01:38 PM
