Building N/A block project... 2.0 b16 or b18c
Old Mar 18, 2003 | 05:42 AM
00 FBP ItR's Avatar
Default Building N/A block project... 2.0 b16 or b18c
i'm gonna start on my 2.0 project... and i was wondering should i resleeve or deck a b16 or b18c block? i still want to retain oil squirters and wanting to use a block designed for vtec.... i'm not a fan of hybrid motors(sorry guys ) so no b20 for me.
i was wonder which block/parts to stroke the motor... it'll be under 12:1 CR and should be on jun 3's
i just wanna find out which route i should take right now, and seeing what would give me a good r/s ratio.
Old Mar 18, 2003 | 08:01 AM
All Motor Rex's Avatar
Default Re: Building N/A block project... 2.0 b16 or b18c (00 FBP ItR)
Just sleeve the b18c and go big bore. 11.5:1 compression. Wiseco makes good pistons, eagle rods will be fine too. With the right head setup and bolt-ons you can expect 230-240whp. Good Luck.
Old Mar 18, 2003 | 08:29 AM
MARC P's Avatar
Default Re: Building N/A block project... 2.0 b16 or b18c (All Motor Rex)
like mentioned above, go 84.5 or 85 mm bore. Call RS machine to get some prices on sleeving a block. They sometimes have cores.
Old Mar 18, 2003 | 03:07 PM
19924ws's Avatar
Default Re: Building N/A block project... 2.0 b16 or b18c (MARC P)
Yup resleeve and bore, always start big, then if you want you can deck the b18c
Old Mar 18, 2003 | 04:14 PM
xJ.SLOTHx's Avatar
230-240 is kinda high....It'd probably be more like 220~225 or so
Old Mar 18, 2003 | 05:54 PM
J2turbo21's Avatar
I doing the a similar setup.Do a search and look for topics created by me and they should help you alot.Im planning on going with a gsr block sleeve to 84mm with je pistons and very nice head i picked up from dual cams.Im hoping for 12's all motor with the right header.
Old Mar 18, 2003 | 08:00 PM
Default Re: Building N/A block project... 2.0 b16 or b18c (ian)
Not if its done right. I just read about a similair setup that made 240+whp.
[Modified by All Motor Rex, 8:36 AM 3/20/2003]
Old Mar 18, 2003 | 10:49 PM
00 FBP ItR's Avatar
so all i need is to resleeve w/ piston and rods? all plug and play? no crank swapping needed? custom rods? nothing?
Old Mar 19, 2003 | 05:46 AM
Jeff C's Avatar
Use oem b18c crank, Eagle b18c rods and pistons to fit your bore.
You might want to get the headgasket bored also to match the block bore.
Old Mar 19, 2003 | 05:48 AM
b19coupe's Avatar
If you resleeve a B18C, no crank swapping necessary. Custom pistons and rings, compression ratio of your choice, some Eagle or Crower rods, and your block will be good to go. The trick to making power is in the head.
Old Mar 19, 2003 | 07:44 AM
Default Re: Building N/A block project... 2.0 b16 or b18c (b19coupe)
I agree. Headwork definitely needs to be done right. It would also help to get your intake manifold match ported to your head.
Old Mar 19, 2003 | 09:49 AM
vtecngsr's Avatar
or get individual throttle bodies and have the head ported for the application.
Old Mar 19, 2003 | 12:28 PM
00 FBP ItR's Avatar
i have my head all figured out. portflow/toda/ferrea/skunk2
Old Mar 19, 2003 | 01:26 PM
warwagon's Avatar
yeah rs charges like $913 or you can call importpowerhouse in phoenix at (602) 272-9988 (DAVE) and see if he can hook you up a little better. he deals with rs!!
xkjnboix
Mar 14, 2016 06:16 AM
91efsikevs
Apr 7, 2009 08:09 AM
Jizzo
Apr 25, 2008 09:53 AM
CrazyHB
May 13, 2005 12:29 PM
2080EK
Jan 7, 2002 06:09 PM
