got spark but no fuel?
Old Sep 15, 2003 | 05:56 PM
unvmyS's Avatar
Default got spark but no fuel?
put b16 in 88 civic dx. took the motor out of another car just like it. it worked perfect in other car. but now we have everything the same but there is no fuel coming from the injectors. any sugestions?
Old Sep 15, 2003 | 07:37 PM
Sanj's Avatar
I would first check to see if there is actually fuel in the tank, loosen the banjo bolt at the fuel filter and turn the key on and check for fuel, check for injector pulse using a noid light. If u got no injector pulse width, i would check the main relay, check fuel pump ground., ecu. Check all connectors to make sure they are clean and tight. Let me know how it goes and what the fix was, i'm interested in knowing. Hope some of my ideas help u get ur beast started!
Old Sep 16, 2003 | 05:15 AM
T4eg's Avatar
Default Re: (Sanj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sanj &raquo;</TD></TR><TR><TD CLASS="quote">loosen the banjo bolt at the fuel filter and turn the key on and check for fuel
Thats what i would do. If you get nothing you know you got something wrong with the fuel pump circuit
b17itr
Feb 7, 2011 07:45 PM
Christopherian1982
Dec 31, 2008 08:17 AM
eric416
Oct 10, 2005 09:29 AM
ek_slut
Sep 23, 2005 02:00 PM
screen_name
15
Apr 17, 2005 09:19 PM
