NO VTEC?!!!
Old Sep 17, 2003 | 10:40 AM
BigIslandBoi's Avatar
Default NO VTEC?!!!
B18C1 into OBD0 90 integra
parts used:
OBD0 engine harness
OBD1 P72 ECU
ODB0-OBD1 conversion harness.
Car runs fine but no VTEC. Whats wrong? anyone know how to fix this?
Old Sep 17, 2003 | 10:47 AM
mmuller's Avatar
Mad Scientist
Default Re: NO VTEC?!!! (BigIslandBoi)
any cel's?
Old Sep 17, 2003 | 10:51 AM
haggar's Avatar
Default Re: NO VTEC?!!! (mmuller)
Did you make sure that the wires were added to operate the VTEC solenoid?
Old Sep 17, 2003 | 10:53 AM
Default Re: NO VTEC?!!! (haggar)
no cel's...and yes wires were added for the VTEC...could it be that the VTEC selonoid is bad?
Old Sep 17, 2003 | 10:57 AM
mmuller's Avatar
Mad Scientist
test it, give 12v to it and hear if it clicks.wiring all ok?
Old Sep 18, 2003 | 12:15 AM
used the P72 ECU and no VTEC.......used another OBD1 ECU and the VTEC kicks in....whats wrong with my P72?
Old Sep 18, 2003 | 07:27 AM
PHiZ's Avatar
Maybe it's vtec drivers are blown.
what was the other ecu you used usdm or jdm?
how are you scanning for CELs?
Also, a lot of chipped programs don't have the diagnostic CELs...
-PHiZ
Old Sep 18, 2003 | 11:22 AM
Default Re: NO VTEC?!!! (PHiZ)
the other ECU was a Type R ECU...not sure if it was usdm or jdm...does the blown vtec drivers mean i cant use the p72 anymore?
Old Sep 18, 2003 | 11:49 AM
rsbad454's Avatar
what do you think..........? if it doesnt work then dont use it...........
Old Sep 18, 2003 | 12:04 PM
mmuller's Avatar
Mad Scientist
Default Re: NO VTEC?!!! (rsbad454)
well...if you switched ecu's and vtec worked then its obvioulsy the ecu
Old Sep 18, 2003 | 06:43 PM
PHiZ's Avatar
you could use it on an LS, or send it to someone and see if they can repair it. (Like me.)
-PHiZ
Old Sep 24, 2003 | 11:25 AM
the shop where my cars at said that all i need to do was chip the p72 with a racing chip and then the VTEC will work. They said that the VTEC is RPM activated. is this true?
By the way, the type R ECU that I used which made VTEC work was chipped.
Old Sep 24, 2003 | 01:26 PM
PHiZ's Avatar
ARe you sure you're not throwing any codes?
-PHiZ
Old Sep 24, 2003 | 01:41 PM
the shop said there was no codes.
Hatchman98
Jul 18, 2007 03:22 PM
compwc18
Feb 21, 2004 06:07 PM
ridestrt
Jan 20, 2004 12:18 PM
Project92Hatch
Apr 17, 2003 10:52 AM
