Differentiate between B18CR and B18C
Old Sep 16, 2003 | 07:29 PM
gamakichi77's Avatar
Default Differentiate between B18CR and B18C
anybody can teach me how to differentiate B18CR ( Type R ) Block and B18C GSR Block? How can i see it? I'm intend to buy B18CR block from my used parts dealer here in Malaysia. I don't want cheated by the seller later on. If can any picture for my good reference.
Old Sep 23, 2003 | 03:29 PM
tegbuilder's Avatar
Default Re: Differentiate between B18CR and B18C (acidburns_di)
On the block, one will say b18c1 (gsr) and the other will say b18c5 (type r)
a b18c5 will also have domes on the pistons whereas the gsr will not
Old Sep 23, 2003 | 04:55 PM
dmotoguy's Avatar
Default Re: Differentiate between B18CR and B18C (tegbuilder)
im not to sure if those would be the correct markings for an asian motor... i think they would both say b18c... dont hold me to that though
Old Sep 23, 2003 | 05:22 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegbuilder &raquo;</TD></TR><TR><TD CLASS="quote">On the block, one will say b18c1 (gsr) and the other will say b18c5 (type r)
a b18c5 will also have domes on the pistons whereas the gsr will not</TD></TR></TABLE>
you are wrong only on USDM motors do they have a number after the letter.
B16A JDM
B16A1/2 USDM
B18C5 USDM ITR
B18C JDM
Old Sep 23, 2003 | 05:27 PM
XrcR6's Avatar
dmotoguy is right, if your in Malaysia you'll probably be looking at JDM motors and they all say B18C regardless. B18C5 was specifically US/North America.
If its long blocks visually, the red valve cover is a start, but anyone can change that easily. You can then go by the intake manifolds. The GSR has the dual runner manifold that looks different from the usual Honda manifold. Search for some pics on H-T it should be an obvious difference.
Old Sep 23, 2003 | 05:28 PM
poison's Avatar
Default Re: Differentiate between B18CR and B18C (AK1200)
The engine code, and compression ratio are also different. Depening on the year
Old Sep 23, 2003 | 05:31 PM
Default Re: Differentiate between B18CR and B18C (poison)
thanks to all for the great and useful info.
Old Sep 25, 2003 | 09:50 PM
tegbuilder's Avatar
Default Re: Differentiate between B18CR and B18C (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">im not to sure if those would be the correct markings for an asian motor... i think they would both say b18c... dont hold me to that though</TD></TR></TABLE>
Thanks for the correction guys as well.
Old Sep 26, 2003 | 04:41 PM
mugenracer's Avatar
on the B18C head will be stamped P72, i think its either P73 or P30 on the ITR motor head
linkdeezie
Dec 9, 2018 07:35 AM
26street510
Sep 23, 2006 01:37 AM
4drferio
Jul 24, 2006 12:43 AM
aznej2
Oct 22, 2005 02:53 PM
sleeperHatch
Aug 22, 2005 10:59 PM
