Searched......what's wrong?
Old Oct 17, 2004 | 09:12 PM
94dxt's Avatar
Default Searched......what's wrong?
I am throwing code 9 (cyp-cylinder sensor). My car (94 dx hatch z6 turbo) was driving fine then once in awhile it would spontaniously bog, occasionally stall. Then (now) it just wouldn't/won't start. What's most likely wrong? I haven't yet checked for spark yet as I need an assistant.
thanks
Old Oct 18, 2004 | 03:20 AM
hondaguyef's Avatar
Default Re: Searched......what's wrong? (94dxt)
The CYP sensor (basically crank angle sensor) is built into your dizzy. The bogging is normal when this goes bad because the CYP determines the timing for the fuel injection and ignition on each cyl. If I were you I would just replace the dizzy.
Phil
Old Oct 18, 2004 | 01:37 PM
94dxt's Avatar
Default Re: Searched......what's wrong? (hondaguyef)
is there a reason why i can't just replace the sensor?
Old Oct 18, 2004 | 02:48 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt &raquo;</TD></TR><TR><TD CLASS="quote">is there a reason why i can't just replace the sensor?</TD></TR></TABLE>
I am sure you can. You'll have to Cann another dizzy to do so. The sensor itself will cost you more than a NEW dizzy. The only Item I ever replace in Dizzzies is the ICM. Anything else I just replace the dizzy.(exluding cap & rotor...obviously.)
Phil
Old Oct 18, 2004 | 07:29 PM
94dxt's Avatar
can this code mean that there is something else wrong with the motor? I just don't want to replace the dizzy for nothing.
Old Oct 18, 2004 | 07:52 PM
kickerx's Avatar
If you replace the dizzy, then you'll know that won't be your problem = )
Sometimes replacing questionable parts is the only way to isolate a problem, don't you agree? I spend a great deal of money doing things this way when necessary, and as a result I have a car that is dependable and maintained. When something goes wrong, I can immediately dismiss many components that could have contributed to the malfunction.
Regarding the $ aspect of it: I'm in college and I'll tell ya, money isn't exactly rolling in ... but if you're going to fix something, might as well do it right.
Plus, you'll be able to sleep well knowing that your new dizzy will not give you any problems in the near future. So sleep tight!
-M
Modified by kickerx at 12:10 AM 10/19/2004
Old Oct 18, 2004 | 08:05 PM
drdisco69's Avatar
Default Re: Searched......what's wrong? (kickerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kickerx &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes replacing quationable parts is the only way to isolate a problem</TD></TR></TABLE>
Listen to this man.
Steven Cortez
Nov 14, 2016 09:49 PM
BONNARSKI
Oct 13, 2012 08:47 PM
951parts
Aug 9, 2012 11:43 AM
vg7z
12
May 20, 2005 05:09 AM
yellowwinter
Feb 13, 2005 11:21 PM
