Bad o2 sesor?
Old Oct 26, 2004 | 06:59 AM
cwood84's Avatar
Default Bad o2 sesor?
I have a 94 civic with a b18c1 engine swap. The check engine light as been on for a while now and would usually go on at about 5000 rpms when the car sputtered but then the car would be fine as long as the lgihts on. Now when i start the car it will idle normal around 1000-15000 rpms then all of a sudden the rpms go down to 500 and below,,the car sputters and stalls. What do u think?
Old Oct 26, 2004 | 07:02 AM
rev-speed's Avatar
why don t u pull the code
sounds like u need to adjust the idle
screw on upper front to throttle body
Old Oct 26, 2004 | 05:46 PM
cwood84's Avatar
Default Re: (4cylinder)
anyone else?
Old Oct 26, 2004 | 06:13 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder &raquo;</TD></TR><TR><TD CLASS="quote">why don t u pull the code</TD></TR></TABLE>
That's what it's there for, to tell you what's wrong.
Old Oct 26, 2004 | 06:24 PM
cwood84's Avatar
Default Re: (drdisco69)
im gonna try to pull it on thursday but regular mechanics have probs pulling it cause of the obd2 to 1 conversion not to mention my jun chip, they never get a read off it,What are the symptoms of a bad 02 sensor?
Old Oct 27, 2004 | 05:57 AM
robbieshonda's Avatar
Default Re: (cwood84)
symptoms of bad o2
primary goes out..car runs like **** and smells like raw gas
secondary goes out..you wouldnt know without the check engine light and code because it only lets you know the cat is bad
h23prelude
Jun 8, 2010 02:16 PM
13btJim
Mar 10, 2010 07:06 AM
oh_lee_allen
May 2, 2007 04:47 AM
Jamied
41
Mar 21, 2006 05:49 PM
