ls/vtec problems!
Old Oct 25, 2004 | 06:30 AM
ReV LiMiT's Avatar
Default ls/vtec problems!
i just started up my ls/vtec in my da for the first time yesterday. i started it up and let it idle for about 15 minutes. i changed the filter and the oil and took it out for a quick, easy drive up my block. i come back to check my fluids and it looks like there are small oil droplets in my anti-freeze. did i pop a head gasket? i dont think i did becuase i used the arp head studs and torqued them down perfectly. does anyone know what could have went wrong. also the engine smokes a little bit when i drive it. other then that the car runs beautifully.
thanks guys
Old Oct 25, 2004 | 06:36 AM
drdisco69's Avatar
Default Re: ls/vtec problems! (9d DA6 TEG)
Can't go wrong with a compression and leakdown test.
Old Oct 25, 2004 | 08:12 AM
rev-speed's Avatar
what color is the smoke?
doe it smoke at full throttle or part?
Old Oct 27, 2004 | 06:41 AM
ReV LiMiT's Avatar
Default Re: (4cylinder)
the smoke is blue. it smokes at partial throttle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Can't go wrong with a compression and leakdown test.</TD></TR></TABLE>
i would if i could.... but i dont have the tools for it.
thanks
mathewb20
Nov 2, 2011 02:29 AM
550whpcivic
Nov 30, 2009 08:22 AM
punkracer
Oct 23, 2004 07:36 PM
thad
Apr 1, 2004 07:30 PM
Phuc yiu
Jul 16, 2002 01:13 AM
