oil light will not turn off
Old Oct 24, 2004 | 12:09 PM
Xxcivic99xX's Avatar
Default oil light will not turn off
My friend is tryin to find out why he oil light turned on. He has 120K miles on his D16z6 motor. The car runs fine with the light on. he had first changed out the oil pump. the oil light used to jus turn on for a few seconds and then turn off, then after a few weeks the light just stayed on. The oil level was always fine. he had decided to do an oil change to see if it would help and metal flakes came out.
Has this happened to anyone before?
he has the motor out of his car now, and he a DX motor, but the dx motor seized up on him and he wants to use the old D16z6 motor now
Old Oct 24, 2004 | 12:13 PM
Kamin's Avatar
Default Re: oil light will not turn off (Xxcivic99xX)
there are 2 options
1) bad oil pressure sending unit or wiring.
2) real, true, low oil pressure.
if you saw metal flakes in the oil, its probably not a sending unit or wiring problem. i would get ahold of an oil pressure testing kit and see for sure tho. no point replacing parts without knowing the root of the problem.
Old Oct 24, 2004 | 04:48 PM
drdisco69's Avatar
Default Re: oil light will not turn off (Kamin)
lol, he's just killing one motor after another. If he's got low oil pressure and metal **** is coming out, it might be a bad bearing, or several. I would look at the oil pump too.
Old Oct 24, 2004 | 06:31 PM
Default Re: oil light will not turn off (drdisco69)
oil pump was replaced. bad bearings cause low oil pressure?
Old Oct 24, 2004 | 06:36 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xxcivic99xX &raquo;</TD></TR><TR><TD CLASS="quote">oil pump was replaced. bad bearings cause low oil pressure?</TD></TR></TABLE>
spun ones can.
or it could be another problem that spun the bearings. eithre way sounds like the engine is toast.
PatrickGSR94
Apr 20, 2017 05:18 PM
hbyrd8701
Apr 6, 2010 12:52 PM
user 93082343
14
Mar 30, 2009 10:34 PM
MUGEN_EG95
10
Oct 25, 2007 07:24 AM
IH82LOSE
Jan 7, 2004 06:00 AM
