what ECU to use? H22
Old Oct 25, 2004 | 12:07 PM
dj_seloe's Avatar
Default what ECU to use? H22
got a stock H22 with dc 4-2-1 header
2 1/4 inch piping
i was told by the preveous owner that the swap came out of a 97 jdm lude
I got the car this way i don't even know what ECU is in it but, the REV limter is hitting 65 or 68 I don't know if it's the ECU or if it's just fucked up?
does anyone know what ecu a 97 prelude came with?
can sombody help?
thanks in advance
Modified by dj_seloe at 2:50 PM 10/25/2004
Old Oct 25, 2004 | 03:24 PM
Honda Sport's Avatar
are you sure you have a h22a in there? sounds like you have a h23a1. also check to see what ecu you have. any CELs.
Old Oct 25, 2004 | 11:19 PM
hqrcrx's Avatar
Default Re: (Honda Sport)
bump
Old Oct 26, 2004 | 07:50 AM
dj_seloe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you have a h22a in there? sounds like you have a h23a1. also check to see what ecu you have. any CELs.</TD></TR></TABLE>
yes h22a p13 ECU
Old Oct 26, 2004 | 11:53 AM
Katman's Avatar
Default Re: what ECU to use? H22 (dj_seloe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_seloe &raquo;</TD></TR><TR><TD CLASS="quote">I got the car this way i don't even know what ECU is in it but, the REV limter is hitting 65 or 68 I don't know if it's the ECU or if it's just fucked up?
97-01 preludes use an OBD2a P5M ecu.
6800rpm redline sounds to me like an Auto ecu's redline.
See if you're getting a check light for code 19, if so, you have an Auto ecu.
what year is your car?
Old Oct 27, 2004 | 07:51 AM
dj_seloe's Avatar
Default Re: what ECU to use? H22 (K@man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K@man &raquo;</TD></TR><TR><TD CLASS="quote">
what year is your car? </TD></TR></TABLE>
thanks for the info. bro.
ill check that out
and thanks again...
EjSex
Feb 26, 2007 03:19 AM
JasonST
Jan 30, 2006 08:04 PM
Godspeed94
Apr 7, 2005 12:54 PM
lakerschamp2000
Jan 30, 2005 10:23 AM
