does the pilot bearing contain grease inside?
Old Oct 25, 2004 | 01:38 PM
SiRkid's Avatar
Default does the pilot bearing contain grease inside?
Inside the bearing. Is it lubed with some sort of grease?
i took off my flywheel and the bottom half the pilot bearing had this weird goopy **** like grease on it...the consistancy is like molasses. it is also in the same position on the end of the crank. i dont think its oil from the motor.
it smells wierd..not like oil or tranny fluid.
i did have tranny issue and fluid got all over the place in there but i dont see it being that either because of its consistancy...
if it is indeed grease from the bearing... guess I shoudl change it ?!
Old Oct 25, 2004 | 06:37 PM
doublejz's Avatar
Default Re: does the pilot bearing contain grease inside? (SiRkid)
im pretty sure its a sealed bearing with grease in it
Old Oct 25, 2004 | 08:42 PM
mmuller's Avatar
Mad Scientist
yeah, they are lubbed inside, change it
Old Oct 25, 2004 | 08:46 PM
93lsd's Avatar
do you have a oil leak inside the housing area..
Old Oct 26, 2004 | 03:35 PM
SiRkid's Avatar
Default Re: (93lsd)
no i dont.
I beleive its bearing grease... cause by wobbling of the input shaft.
new one is here tomorrow.
eda6
Jan 26, 2008 03:26 PM
red_crx
Aug 20, 2007 08:15 AM
vg7z
14
Jul 23, 2005 06:33 AM
pentaq
Feb 15, 2005 09:59 PM
basketcase
Jan 21, 2003 04:39 PM
