Drop motor assembled into car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver »</TD></TR><TR><TD CLASS="quote">i put my motor in from the top, everything was on except the header, which was a 1 piece (not stock)
just remove the radiator and make sure everything is out of the way.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">Yeah but this is being done in a garage, no lifts, only jacks and stands</TD></TR></TABLE>
And thats all you need to install an engine from the bottom - jack the front end up high enough to allow the engine to be slid in, then just drop the car onto the engine. At this point, lining up mounts becomes a lot easier since the engine is sitting level with the mounts.
You may need to jack the front end up, secure that position with a jackstand, then using a 4x4 for some extra height, continue to raise the front end even higher.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">
You may need to jack the front end up, secure that position with a jackstand, then using a 4x4 for some extra height, continue to raise the front end even higher.</TD></TR></TABLE>
Yeah but id definetly have to take my rear bumper out for that one cause my car sits low
if you have a cherry picker like i do then its way safer to do it from the top. Take off the throttle body have like a friend on each side to guide it in and wala. I'm sure even with the above mention parts still on you could do it.
