shorter EK lca's
Old Oct 24, 2004 | 08:19 PM
deeksmooth's Avatar
Default shorter EK lca's
i've heard in the past that SRR LCA's are shorter than stock spec, but andy and perpetual concepts straightened me out on that idea. does ANY company make shorter LCA's?
Old Oct 24, 2004 | 09:54 PM
LX4CYL's Avatar
Default Re: shorter EK lca's (citrEK)
wouldn't shorter LCAs=positive camber?
Old Oct 25, 2004 | 05:53 AM
drdisco69's Avatar
Default Re: shorter EK lca's (LX4CYL)
Not only that, but you would have a very screwed up suspension geometry. Dare I ask why you want shorter lower control arms?
Old Oct 25, 2004 | 06:47 AM
deeksmooth's Avatar
Default Re: shorter EK lca's (drdisco69)
because for some reason with my CTR 5 lug, if i adjust my camber to "normal", it rubs on my fender. it just seems to stick out a hair extra w/ that setup for some reason. it just looks like **** how the wheel sits.
Old Oct 25, 2004 | 07:06 AM
drdisco69's Avatar
What do you have your camber set at? If you have wide tires and wheels, lower the car and set the camber to 0, it'll probably rub. Making the lower control arms shorter will pull the bottom of the wheel inward, causing the top to more outward, giving positive camber. If you try to remedy the situation by adjusting the upper control arms, eventually you might end up with axles that bind up and really wierd suspension geometry that'll probably lead to fucked up handling. A good solution is giving the car around -1* to -1.5* camber. This isn't enough to really destroy a tire, but can help with tire rub.
Let us know what wheel and suspension upgrades you have for more info.
Old Oct 25, 2004 | 07:16 AM
deeksmooth's Avatar
my suspension setup is listed here...
http://droq.dyndns.org/d/ek_mods.htm
Old Oct 25, 2004 | 07:40 AM
drdisco69's Avatar
With that kind of offset, you shouldn't have too much trouble fitting things. Is the camber set to 0?
PS, dyndns and OEM exhaust rule!
Old Oct 25, 2004 | 07:44 AM
deeksmooth's Avatar
i'll try and get pics tonight... the camber isn't the worst i've seen, but its not the greatest. i want to get my fenders rolled, but don't want to do it myself. i think if i get them rolled, i can set the camber closer to where i want it.
Old Oct 25, 2004 | 07:48 AM
drdisco69's Avatar
I have about -1.7* on mine with 15x7, and I never rub. The tire wear is fine too. Post pics and we'll see.
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
Honda knowledge
Apr 15, 2015 10:41 AM
idreamHonda
Suspension & Brakes
Apr 16, 2005 01:44 PM
Tyson
Dec 1, 2004 03:13 PM
RineRacing
23
May 30, 2002 06:06 PM
