tuning v-afc by looking at dyno sheet?
can i tune the vafc myself by looking at the dyno sheet?
this is with pulley's, cai/h/e
Modified by luap at 3:09 PM 10/26/2004
Modified by luap at 3:10 PM 10/26/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote">What is your question? </TD></TR></TABLE>
he wants to know if he can tune the v-afc by just looking at his dyno sheet.
I'm not too sure if you can but the best way is on a dyno.
thats how we tune
looking at the dyno plot after the run.
but u ill need to do a run after u make ur adjustments to see the out come
if thats a sae dyno jet number its really good if its not a itr
you can tune but you really need to be on the dyno to do it. You really just need to get the air/fuel leaned out a bit. Ideal for n/a is prolly around 13.0 -13.5:1 a/f ratio. (but u tune for where the power is, a reason u need to keep dynoing while ur tuning)
Also, you can adjust the vtec engagement to be a lil smoother aswell.
You really need a dyno and a wideband o2 to tune it properly.
generally if your talking stock fuel pressure about 5% lean on a vafc would raise the a/f ratio about a point. You could take about 4-5 percent away and that might net you some power but i would rather u do it on a dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luap »</TD></TR><TR><TD CLASS="quote">when would u adjust anything under the narrow throttle setting?</TD></TR></TABLE>
When you want to adjust at partial throttle, when you're crusing. You can adjust it for fuel economy when crusing, but for power when at WOT. This is the way most people tune them.
juniestyle
Apr 12, 2006 10:20 PM
