transmission suggestions?
Old Oct 25, 2004 | 06:36 PM
HOND PWR's Avatar
Default transmission suggestions?
I'm replacing my transmission this week. I'm trying to decide between a Y1 or a S1...Will be used in my ITR powered CRX.
Which 1 should I go with?
What are the gear ratios?
Is there anyway to tell if they have lsd?
thanks...
Old Oct 25, 2004 | 07:23 PM
doublejz's Avatar
Default Re: transmission suggestions? (HOND PWR)
Here is more then you wanted
B16A (Cable), B16A2 (Hydro), B16A3(Hydro):
S4C, S80, Y80, Y21, Y1 (optional LSD)
As most of you know the B16A was featured in Japan between the years of 1989 through 2001. This engine has had several different transmissions mated to it causing some potential confusion.
First, it's important to realize that first generation B16A's came with cable transmissions. The Y1 came with optional factory LSD and should have LSD stamped on the transmission. Determining whether or not a transmission has LSD is very simple, just look into the differential and see if its opened or closed. For those not familiar with this, you'll either see a set of gears that form a closed cylinder, or you'll see an open differential with a bar splitting the middle.
Typically these transmissions have had weak synchro's in 2nd, 3rd, and 4th gears with 3rd gears crunching the most. Its also worth noting that all of the transmissions minus the Y1 have very weak open differentials making it essential that you upgrade if your putting a lot of power to the ground.
As far as gearing, these transmissions are all pretty short. Here is a listing of the gear ratios and final drive, courtesy of http://www.bseries.net.
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
In conclusion, this transmission is good for all motor and should bring between 500-700 if its hydraulic while cable transmissions are worth between 400-600. Please be careful that the transmission you're buying doesn't have bad synchro's because a lot of them have been beaten on and this is the first problem you'll have. Plus, if you're making a lot of power, 170 to the wheels, be prepared to replace your differential because these can be broken with regularity.
B16B (Hydraulic):
S4C (LSD)
The transmission found in the Civic Type R is highly sought after and very rare. Its gear ratio's are identical to that of the B16A's but has a stronger limited slip and dual synchro's in 2nd, 3rd, and 4th gears. Expect to pay between 1000-1200 for a genuine CTR transmission because they're rare and well worth the price. Its also worth mentioning that these transmissions are Hydraulic type.
B17A1 (Cable):
YS1
This transmission is found on the rare "blacksheep" of b-series motors. The most important feature here is that its cable-type. This means you can bolt this into any 93 and older integra and 91 and older civic without having to change to hydraulic. The synchro's on this transmission are still considered weak, however the gearing is very good for all motor applications as its identical to the B16A transmissions. Finally, this transmission did not have factory LSD, so keep that in mind when someone is trying to tell you otherwise. Look to pay between 400-600 dollars for this transmission, although its going to be difficult to find and usually when you do, there is something wrong with it.
B18A1 (Cable):
YS1
Again, you'll see how Honda didn't help us out any with the stamping on this transmission. These transmissions however, are much different in there gearing. This transmission has a longer first and second gear with slightly longer 3rd and 4th gears. The final drive is still 4.40:1 making this a possibility for all motor applications, but not your best choice. You'll be able to find this transmission in 90-93 Integra's and they're all cable-type. The prices for these should range between 200-400 for clean, good working units. Paying anymore is pointless, as these transmissions are everywhere.
B18B1 (Hydro):
S80/Y80
This is probably the easiest b-series transmission to find because it's found in every non-VTEC 94-01 Integra. Most notably, this transmission is the longest of all b-series transmissions and has the weakest synchro's and weakest differential. The final drive is 4.266:1 and each of the gears is longer compared to its B16A counterparts. For boost, a lot of people like the gearing of this transmission, plus gas mileage is great and they're very cheap. Look to pay no more than 500 for a clean LS tranny because they're everywhere.
Here is a look at the Specs.
1st: 3.230
2nd: 1.90
3rd: 1.269
4th: 0.966
5th: 0.714
Reverse: 3.000
Final Drive: 4.266:1
B18C:
S80/Y80 (Optional LSD)
The transmission found in JDM GSR's is very popular and overall an excellent transmission. For all motor and boost applicatiosn this transmission has excellent gearing and a stronger differential compared to its B16A and B18B counterparts. The transmissions with LSD should have "LSD" stamped on the casing and to make sure, inspect the differential and use the parameters I described before to identify whether or not the transmission really has LSD. Look to pay between 700-1200 for this transmission depending on whether its LSD equipped. Also worth mentioning, these transmissions are all hydraulic.
Here is a look at the specs:
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.400
B18C1:
Y80
This transmission is found in all USDM GSR's. Although LSD was not offered these transmissions are still highly sought after because of their stronger differentials and optimal gearing. For those not interested in ultra-short gearing this transmission provides the perfect balance between acceleration and top end. Look to pay around 700-1000 for these transmissions.
The specs are the same as above:
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.400
B18C5:
S80 (Helical LSD)
This transmission is one of the best B-series transmissions Honda has offered in its vehicles. Every gear has dual synchro's and the gearing is perfect for all motor applications. Plus, LSD is standard and will be stamped on the housing. Look to spend between 1200-1400 for these transmissions because of their quality, LSD, age and gear ratio's. Finally, if there is some question about whether or not you're S80 has 4.4 final drive or 4.7 final drive you can check the transmission housing. The code "4jhd" means 4.4 final drive was offered as original equipment, while "ne3" signifies 4.78 final drive.
The specs are below:
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
B18C (JDM Type R):
S80 (Helical LSD)
JDM Type R transmissions are the best for all motor applications where acceleration is emphasized most. All 98 and up JDM Type R transmissions came with 4.785 final drive with the same 1st, 2nd, 3rd gears as the USDM Type R. To make highway driving more tolerable, the 4th and 5th gears are the same as GSR transmissions. Look to spend between 1400-1600 for these transmissions because of their final drive and rarity.
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.785
To see if it has a lsd, take out both axles and look through the tranny. If you can see straight through it its not an lsd, but if you see a post in the middle then lsd
Modified by doublejz at 4:57 PM 11/2/2004
Old Oct 25, 2004 | 08:58 PM
93lsd's Avatar
very good info.....
Old Oct 26, 2004 | 04:42 AM
95civ's Avatar
wow...great post. Very informative.
Old Oct 26, 2004 | 06:07 PM
HOND PWR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote"> The Y1 came with optional factory LSD and should have LSD stamped on the transmission. Determining whether or not a transmission has LSD is very simple, just look into the differential and see if its opened or closed. For those not familiar with this, you'll either see a set of gears that form a closed cylinder, or you'll see an open differential with a bar splitting the mid
To see if it has a lsd, take out both axles and look through the tranny. If you can see straight through it its not an lsd, but if you see a post in the middle then lsd </TD></TR></TABLE>
Thanks for the info.
I pulled my S1 transmission today...noticed both the S1 and the Y1 has a round rod running the the differential. So I guess if you have a round rod running through it it does not nave LSD?
Old Oct 26, 2004 | 08:08 PM
eda6's Avatar
Default Re: (95civ)
This is good ****.
Old Oct 27, 2004 | 12:37 PM
doublejz's Avatar
if you see a post in the middle then its not a lsd
Modified by doublejz at 9:26 PM 10/28/2004
Old Oct 28, 2004 | 02:24 PM
EJ2-Fluffy's Avatar
Default Re: transmission suggestions? (doublejz)
bump up for some good sticky info.
-Jon
Old Oct 28, 2004 | 04:41 PM
PyroProblem's Avatar
Default Re: transmission suggestions? (CRX-Fluffy)
Actually the "post" or "rod" through the difrential means it is NOT LSD equipped...
On trannies w/ LSD, you can see straight through the diff.
Old Oct 28, 2004 | 05:27 PM
doublejz's Avatar
Default Re: transmission suggestions? (PyroProblem)
yea thanks for the correction, if theres a post its splitting an open diff
Old Oct 30, 2004 | 06:46 PM
8point6's Avatar
I thought that if there was a rod visible, then LSD was equiped..?
Old Oct 30, 2004 | 06:54 PM
mmuller's Avatar
Mad Scientist
Default Re: transmission suggestions? (8point6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8point6 &raquo;</TD></TR><TR><TD CLASS="quote">I thought that if there was a rod visible, then LSD was equiped..?</TD></TR></TABLE>
nope
Old Oct 31, 2004 | 05:27 AM
'91 CRX CornerCarver's Avatar
This is kind of off topic, but i have searched and i can't find an understandable answer! I have a b16a and need a new clutch but i can't find any online for a cable tranny. Where should I look for a good deal and what model of car's usdm clutch is the same as mine. Agian the answer might have been in this post but I don't understand so please don't flame!
Old Nov 1, 2004 | 11:31 AM
8point6's Avatar
Default Re: transmission suggestions? ('91 CRX CornerCarver)
I believe any B series cable tranny clutch will work. The cable b18 clutch from the G2 Integras should work. I'm not sure if the G2 GSR's, (b17), were cable or not. Hope this helps.
Old Nov 1, 2004 | 11:40 AM
purplegsr's Avatar
G2 trannies from 90-91 were small spline, and 92-93 were large spline. All were cable, even GSRs. You would probably want a small spline one, from 90-91 S1/YS1 cable tranny (found on 90-91 LS, GS, RS integras).
Old Nov 1, 2004 | 11:53 AM
8point6's Avatar
Default Re: transmission suggestions? (purplegsr (Exospeed))
What is the difference between a small and large spline transmission?
Old Nov 1, 2004 | 12:13 PM
purplegsr's Avatar
A small spline transmission will have an input shaft with more numerous, small splines. While a large spline input shaft will have thicker splines, but fewer in number. If you try to use a small spline clutch with a large spline input shaft, they won't match up.
Old Nov 1, 2004 | 10:34 PM
8point6's Avatar
I learn something new every other day, thanks.
Old Nov 2, 2004 | 06:36 AM
DaX's Avatar
DaX
Loved
Community Favorite
http://info.honda-tech.com/ind...atios
valtersB20
Jan 9, 2008 06:27 PM
jdmboiz
Nov 16, 2007 02:17 PM
chet
Jun 20, 2003 12:32 PM
infamousALLMTR
Apr 4, 2002 12:43 AM
