bearing Question (already searched)
Old Oct 22, 2004 | 09:24 PM
AFFIRMED's Avatar
Default bearing Question (already searched)
ok I was installing my acl bearings and used my finger with no glove to put the asembly lube on is this ok?
One more question after installing the main caps and rods how hard should it be to turn the crank?
Old Oct 22, 2004 | 09:40 PM
Kamin's Avatar
Default Re: bearing Question (AFFIRMED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFFIRMED &raquo;</TD></TR><TR><TD CLASS="quote">ok I was installing my acl bearings and used my finger with no glove to put the asembly lube on is this ok?
One more question after installing the main caps and rods how hard should it be to turn the crank?</TD></TR></TABLE>well its really hard to say, there are 2 schools of thought, 1 the oils on your finger can be transfered to the bearing surface and shorten the life of them, 2 dosent really affect anything with the assy lube on there.
and the crank should have noticable drag but should still turn freely. also, only rotate the crank as little as possible once its all installed.
Old Oct 22, 2004 | 10:44 PM
PHiZ's Avatar
Default Re: bearing Question (Kamin)
I would imagine that after one combustion cycle, there is nastier stuff in the oil that a microscopic amount of finger oil?? no?
-PHiZ
good question though, I like the attention to detail.
Old Oct 23, 2004 | 01:22 AM
Mike K's Avatar
Default Re: bearing Question (PHiZ)
i never thought about that really. for one, i always assemble engines with nitrile or latex gloves on, and when i'm applying lube to the bearings before setting the crankshaft in, i just squeeze it out from the tube and don't really spread it around. as you torque the main caps, the lube will spread out on its own.
how much an engine should turn with X amount of force is different to every engine builder. i like to build my engines loose, so after a good swing with the 19mm gearwrench, i like to se almost 360 degrees of rotation, if not more. depending on pistons, rods, etc.
Old Oct 23, 2004 | 05:56 AM
AFFIRMED's Avatar
Default Re: bearing Question (Mike K)
thanks for the help
Lordofdark176
Aug 30, 2008 11:07 PM
mySIisLOVE
Feb 25, 2008 11:54 AM
cartuneracing
Jun 25, 2005 07:25 PM
JustLooking
Nov 25, 2003 09:40 PM
JustLooking
Nov 23, 2003 02:12 PM
