engine wont start----elp please
Old Oct 24, 2004 | 03:13 PM
CivicBwoy's Avatar
Default engine wont start----please help
i have just finish swaping a 99 ls motor in my 93 hatchback.
i used a 94 ls wiring harness, throttle body, distributer and ecu
i have 440 dsm injectors, and a 91 accord resister box wired in. this setup ran perfect on my 94 ls motor.
engine management is a greddy emanage
now the car wont start, it turns over like it wants to start but it doesnt. fuel is there, spark is there, the timing is correct........
what could be the problem...?
Old Oct 24, 2004 | 03:28 PM
CivicBwoy's Avatar
Default Re: engine wont start----please help (CivicBwoy)
i was trying to start it again, i turned the key and held it for about 10 seconds, then a check engine code came on
the code is 16 for injectors
am thinking that i should install the stock 94 ls injectors back in and take out the resistor box
could this be causing it to not start?
i am going to switch them tomorow
Modified by CivicBwoy at 6:59 PM 10/24/2004
Old Oct 24, 2004 | 06:02 PM
CivicBwoy's Avatar
still not starting
Old Oct 25, 2004 | 08:43 AM
CivicBwoy's Avatar
i switch the throttle body and the car started
but i am getting code 16 for injectors, the injectors are fine i checked them, so i am thinking that the wiring is causing a problem
how do i fix this?
Old Oct 25, 2004 | 08:56 AM
rev-speed's Avatar
did u use hondata wireing diagram to wire
the resistor box?
if so its wrong
Old Oct 25, 2004 | 10:56 AM
CivicBwoy's Avatar
Default Re: (4cylinder)
whats the correct wiring diagram?
do you know where i can get it from?
Old Oct 25, 2004 | 07:10 PM
Gqracer's Avatar
Default Re: (CivicBwoy)
did u changed the fuel pump to a Ls or Gsr?
TheCrimsonGhost666
Mar 30, 2014 09:42 AM
SCerbanger
Jun 29, 2010 02:39 PM
dohcter g
Mar 22, 2005 11:43 AM
turbochris
Jun 26, 2002 08:40 PM
