VTEC Wiring Question and MAP Sensor Wiring HELP NEEDED.......ASAP
need how to wire up vtec on a sohc vtec into my hatch that had a d15 in it w/out vtec. and where do i hook in the map sensor because there are no wires to hook it to on my engine harness - but there are the 3 wires and the sensor on the jdm motor i have - WHAT THE HELL DO I DO ? WHERE THESE WIRES GO? THANKS
MILT
MILT
well wat year is your car? and model.......vtec will either be by an msd rpm switch and relay, or if your obd-1 then a p28 ecu and rewiring a couple wires
