Problem: EG w/B16A won't drive
Old Oct 25, 2004 | 02:35 PM
DexterThEG's Avatar
Default Problem: EG w/B16A won't drive
Just swapped my EG with a JDM B16A and GSR tranny. It backed down the driveway, but when I cut the wheel to enter the street, it quit putting power to the ground. The clutch works, and it free revs and sounds like the tranny spins through the gears. I put the AT half-shaft in it because that's all I had. I believe this to be the problem and I've got a MT shaft on its way, but I wonder what you guys think this could be.
Also, I used the passenger side axle from the AT (the B16A came with an auto tranny). It is the same axle as the MT D-series passenger axle, so I assumed the MT B-series passenger axle would be the same as well, no?
Old Oct 25, 2004 | 06:32 PM
doublejz's Avatar
Default Re: Problem: EG w/B16A won't drive (DexterThEG)
you sure that the axle just didn't pop out? if its a one wheel wonder and the passenger side axle popped up, it wouldn't move
Old Oct 25, 2004 | 06:50 PM
Gqracer's Avatar
i think one of the axle just popped out.. you might wanna check both side.
Old Oct 26, 2004 | 12:47 AM
DexterThEG's Avatar
Default Re: Problem: EG w/B16A won't drive (Gqracer)
I'm betting that's what happened now that I've thought about it... it probably would drive fine, and I just didn't have the axle in all the way.
Old Oct 27, 2004 | 06:21 PM
DexterThEG's Avatar
got it going.. guess I should have put in my LSD and I wouldn't have noticed tha axle hanging out so much
c0d0r
Dec 21, 2007 09:33 PM
EKtypeRhaTcH
Jan 20, 2005 09:20 PM
Audi RS4
Sep 10, 2003 02:04 PM
Dank26
Oct 29, 2001 10:23 PM
