HELP
Old Oct 26, 2004 | 08:52 AM
hotinteggy's Avatar
Default HELP
I have a 92 integra 1.8 DOHC. Cold air intake, dc headers, high flow cat, custom exhaust. My integra runs fine when cold but once it warms up it sputters when idling and if u try to come off a light you are SOL. I changed the plugs and they were white... which i believe is too much heat.... so i think it is running lean. I traded my truck for the car so i think everythin was jus ghettod on and not tuned. Any advice? I was thinkin a Walbro 190 fuel pump and a new FPR. Thanks
Old Oct 26, 2004 | 09:39 AM
rev-speed's Avatar
if u think its fuel check the fuel pressure
see what ecu ur running
if the car is rigged
double check vaccum
egr could be routed wrong
Old Oct 26, 2004 | 09:03 PM
hotinteggy's Avatar
Default Re: (4cylinder)
one reason i think it is fuel pressure is because it runs fine while the engine is cold but once it warms up you are fuct
Old Oct 26, 2004 | 09:13 PM
rev-speed's Avatar
hmmm
i haven t seen an o2 sensor on a honda/acura to make it run that bad but it could be.
unplug the o2 sensor
and warm the car up see if its still doing it
Old Oct 27, 2004 | 07:21 AM
hotinteggy's Avatar
But would that make it burn up a set of plugs in about 3 weeks?
HondaMan2380
Sep 21, 2010 03:39 PM
iphatcrxi
Oct 6, 2006 11:41 AM
yz125rider21
12
Jul 20, 2006 12:58 AM
barry11j
12
Sep 29, 2004 08:47 PM
Mike1486
Sep 22, 2004 12:30 PM
