Running lean not enough fuel
Old Oct 25, 2004 | 04:28 PM
Hatch8's Avatar
Default Running lean not enough fuel
My b16 engine is running lean. The spark plugs have pieces of white stuff from detination and are not getting enough fuel. The car stutters sometimes like it is going to stall and like it doesn't have a lot of power and other times it is fine. I have a vtec controller thinking that maybe the air/fuel ratio might not be set right however when I unplugged it the engine light was still on and the car still suffered from this problem. What could be some possibilities as to why the car is running lean? Could it be the O2 sensor? By the way the vtec does still engage. Thanks.
Old Oct 25, 2004 | 05:50 PM
93lsd's Avatar
Default Re: Running lean not enough fuel (Hatch8)
what are you running in the b16 stock or do you have other things in there..
Old Oct 25, 2004 | 06:30 PM
doublejz's Avatar
Default Re: Running lean not enough fuel (93lsd)
have your checked your timing?
HondaMan2380
Sep 21, 2010 03:39 PM
97grnrs
Nov 6, 2006 06:42 PM
w0ng_sta
Sep 7, 2006 10:35 AM
turbo-d
Feb 4, 2005 04:58 PM
BLK99VTECR
Nov 11, 2003 07:36 AM
