Spring Rate and its compression
Old Oct 23, 2004 | 07:19 PM
SlipAngleX's Avatar
Default Spring Rate and its compression
If a spring is rated at lets say 500lbs, to compress it 1in, it would take 500lbs, correct?
To compress it 2 inches it would require 1000lbs?
so 1in (500lbs) + 1in (500lbs) = 2in compression (1000lbs)
with linear spring rates
Old Oct 23, 2004 | 07:22 PM
drdisco69's Avatar
Default Re: Spring Rate and its compression (4DoorTeg)
You are correct. And good for noting that this applies to linear spring rates only.
Old Oct 23, 2004 | 08:18 PM
SlipAngleX's Avatar
Sounds good
thanks!
Godspeed07
Suspension & Brakes
45
Aug 17, 2009 04:07 PM
Natural Aspirations
Suspension & Brakes
28
Mar 19, 2009 06:57 AM
Team Bukkake Sucks!!!
Suspension & Brakes
Jun 13, 2006 10:12 AM
the DR.
Dec 25, 2002 07:01 PM
