need help keyless door handle on 92 hatch problem
Old Aug 19, 2005 | 12:44 PM
dognutz's Avatar
Default need help keyless door handle on 92 hatch problem
I have 4 door rear outer handles off a 92-95 civic and I'm trying to get them to work properly. The trouble is when I unlock/lock the door with power either from door switch or with alarm it messes with the lock it won't unlock and neither handle works (of course cause it's locked still). I must then take the outside handle off then the lock works fine. If I only unlock/lock manually then the handles work fine. I'm using the rod that comes with the hatch do I need the 4 door rod to make this work properly? It seems like its binding slightly but I can't tell where the issue is. I have tried adjusting the length of the rod with no success. I have already searched for info on this topic. Has anyone done this mod with success?
Thanks in advance.
Old Aug 22, 2005 | 11:00 AM
dognutz's Avatar
Default Re: need help keyless door handle on 92 hatch problem (dognutz)
Has anybody out there tried this mod. I need some tips.
Modified by dognutz at 2:59 PM 8/22/2005
alexsneesby
Oct 7, 2009 11:23 AM
flat6turboGT1
Sep 7, 2009 01:02 AM
98PAITR
Mar 17, 2008 05:48 PM
percyv143
May 15, 2006 03:29 AM
MADEINIRAQ
Aug 25, 2004 07:59 PM
