Built ls/vtec how high can i rev it?
Old Aug 16, 2005 | 05:10 PM
B16Civic93's Avatar
Default Built ls/vtec how high can i rev it?
i've got a b18b with eagle rods, je pistons it is balanced etc... the head is a b16 wiht supertech springs retainers and valves.
how high can i safely rev the engine(what will thebottom end handle)
Old Aug 16, 2005 | 05:39 PM
unknown0001's Avatar
Default Re: Built ls/vtec how high can i rev it? (B16Civic93)
The bottom end should handle 10000rpm...but will you be making power there?
what is "ETC..."
what else is done to the block? what cams?
Old Aug 16, 2005 | 05:57 PM
rabius's Avatar
you need to find out the mean piston speed. a b16a has the shortest stroke and it can handle 10k with built bottom end. im not sure how much longer the stroke is on a b18, depending on the stroke, it could probably take 10k too.
Old Aug 17, 2005 | 07:22 PM
rabius's Avatar
ok, i looked into it, and a b18 with a better bottom end, can run about 9k. not much more. there is an article in dsport. they built a turbo b16 and it makes like 360hp up to 8200 rpms, but since they had it re tuned (because the rev limiter hadnt been moved) it makes like 458hp at just under 10k..
there is also a table in there that shows piston speed, the b18 being right about 9k before it gets risky (with a better bottom end).
Old Aug 18, 2005 | 06:12 PM
rhdcrx's Avatar
Default Re: (rabius)
the d sport b16 pushed 480 at 9600 rpm on 18 psi and 91 pump octane
Old Aug 18, 2005 | 06:21 PM
krazie1's Avatar
BANNED
Default Re: (rhdcrx)
coming from a built Ls/vtec
all I can say is this if u have faith in the guy who build it then I would say tune it and find out where the power is made
but if not stay safe and don't do passed 9000 rpms
my builder made his old Purple Crx rev to 10,500 rpms on a big Ls/vtec
so anythign is possible if it is done correctly
Old Aug 18, 2005 | 08:26 PM
pomansouth01's Avatar
Ginger Kid
i think i am gonna answer your question this way... when your cams stop making power, shift gears, dont rev any higher than that. if you have cams that make power to 10k rev to 10k nothing more. Be sure if you are gonna come close to 9k to put something to hold those mains together better than the oil between them. Something like a girdle should work nicely.
Old Aug 22, 2005 | 03:57 PM
B16Civic93's Avatar
Default Re: (pomansouth01)
so you guys are saying that i should have no problem reving the bottom end that high and have to worry about it coming apart?
Old Aug 22, 2005 | 04:05 PM
ThatsMyEG's Avatar
Default Re: (B16Civic93)
I've searched on this topic and found out from peoples experience not to rev past 8500 with h beam eagle rods or your asking for trouble, but anyways id also like to find out some more info on this question..
Old Aug 22, 2005 | 04:59 PM
slomofo's Avatar
GDD Member
Longer the stroke, shorter the redline, everyone knows this, that's why honda set the LS redline low from the factory. Rev above the LS redline and it'll work, but the reliability decreases. One of my customers had his turbo ls/vtec set at 9500, it ran fine...until the rings went out less than a year of hard driving later.
Old Aug 23, 2005 | 01:52 AM
mdixonjam's Avatar
With a built head like you have here, the bottom end should take up to a 9000 Rev Limit consistently with no problems.
We have seen similar setups run at 9000 and 9200 consistently without any problems. I have mine set at 9200 for almost 2 years now.
I would say anything over 9000 gets a little risky though and you need to make sure you are making power up that region for it to make any sense. This will depend on what cams you are using.
Tune your vehicle to where your power starts falling off and set your Rev limit there - if it is above 9000 use common sense please !!!!
Rev Limit: (8.5 Safe; 9K OK; >9K Risky)
Old Aug 23, 2005 | 07:37 AM
mmuller's Avatar
Mad Scientist
what cams are you using...
with most cams you will not have nor want ot rev that high..
Old Aug 23, 2005 | 12:02 PM
B16Civic93's Avatar
Default Re: Built ls/vtec how high can i rev it? (mmuller)
i'm not saying i need to rev that high i'm just saying that i want to know how high it can rev safely or where i should set my limitor incase of a mis shift.
Old Sep 1, 2005 | 02:48 AM
mdixonjam's Avatar
An 8500 rev limit should be safe and should accomodate the full power of most cams for street use (ITR/CTR/Aftermarket Stage I cams).
sloweredcivic
Aug 30, 2005 03:37 PM
b18_4door
Aug 26, 2005 09:51 AM
miksew
30
Sep 13, 2003 09:37 AM
92TurboLS
Sep 13, 2002 06:09 AM
ITRfaithful
May 16, 2002 07:15 PM
