auto to manual...
whats the easiest way to get the pedal assem. out so i can bolt on the manual pedals...
the steering column is in the way.. should i just shimmy it till it comes out.. dont want to cut anything
if you are talking about the brake pedal, which I assume you are since the steering column is in the way, then you should only have to remove the spring on the pedal and the bolt that holds it in. I don't think you need the entire assembly, just the pedal. Atleast on my 92 accord I didn't need the whole assembly.
-Brian
-Brian
grandtheftlunchbox
18
Sep 3, 2008 07:37 PM
nimblecivic
28
Aug 30, 2004 03:12 PM
crx_91si
May 23, 2004 01:22 PM
