ARP Stud Lubricant Application
For those of you that used the ARP Lube that comes with head studs, did you use the lube for puting the studs into the block, bolts onto studs, or both?
Well all but one stud are in the block. The stud on left intake side doesn't want to go all the way down for some reason, should I clean it out with a tap?
totsie7944
Feb 20, 2008 07:27 PM
