how much will bottom end hold...
Old Aug 15, 2005 | 09:52 AM
tobe1424's Avatar
Default how much will bottom end hold...
im building an ls block ...darton sleeves je pistons and rods... stock compression...how much boost you think it will hold
Old Aug 15, 2005 | 01:16 PM
BoOstedEM1's Avatar
Default Re: how much will bottom end hold... (tobe1424)
SO why did you leave it to stock compression..if your turboing..itlll hold probably 15 pounds..of rip..but with the right tunning and set up..higher than that..depending on who did build and how it was done...
Old Aug 15, 2005 | 04:43 PM
pdog37's Avatar
Default Re: how much will bottom end hold... (BoOstedEM1)
i thought higer compression came from better pistons if im wrong what gives u higer compression?
Old Aug 15, 2005 | 05:05 PM
mmuller's Avatar
Mad Scientist
Default Re: how much will bottom end hold... (pdog37)
i think 9.4 comp. is mighty fine for boosting.
its all in the tuning, if done right it will hold more than you want and need.
Old Aug 15, 2005 | 05:15 PM
tobe1424's Avatar
Default Re: how much will bottom end hold... (mmuller)
reason why i left stock compression cuz if i put low compression piston i will be able to boost alot more but on honda it will cause alot of turbo lag and it will take a while to hit that boost on the other hand stock compression you will get more or less the same hp with less turbo lag and more low end power..
Old Aug 15, 2005 | 05:26 PM
Race Egr's Avatar
It will hold 250 kilograms If you pack it tight
Old Aug 15, 2005 | 05:45 PM
mmuller's Avatar
Mad Scientist
Default Re: how much will bottom end hold... (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">It will hold 250 kilograms If you pack it tight</TD></TR></TABLE>
hahaha, that was pretty funny
Old Aug 16, 2005 | 10:13 AM
tobe1424's Avatar
can u convert that into psi for me
Old Aug 16, 2005 | 01:04 PM
EM1B18-R's Avatar
rofl
gorillaglue#4
Apr 27, 2017 06:48 PM
trytomake
Dec 8, 2008 11:30 AM
tobe1424
12
Jan 17, 2006 12:17 PM
accordfreak
Jul 30, 2002 11:57 PM
Adampops
Jan 7, 2002 10:15 AM
