Will an OBD 1 B16 dizzy work on a OBD1 B18C?
Old Aug 17, 2005 | 07:26 PM
BlueShadow's Avatar
Default Will an OBD 1 B16 dizzy work on a OBD1 B18C?
Hey guys,
I have a 95 B18C and I want to replace the dizzy with a brand new one. I see that Full Race had them listed for about $270 but they say OBD 1 92-95 DOHC VTEC motors. What do you guys think?
thanks
Old Aug 17, 2005 | 07:49 PM
drdisco69's Avatar
Default Re: Will an OBD 1 B16 dizzy work on a OBD1 B18C? (BlueShadow)
Yep, all the OBD1 B series distributors are interchangable.
THEUSED's Avatar
Yes
Old Aug 17, 2005 | 11:42 PM
BlueShadow's Avatar
Default Re: (THEUSED)
sweet, thanks guys
Old Aug 18, 2005 | 01:55 AM
BlueShadow's Avatar
Default Re: (BlueShadow)
Hey again guys,
I was also thinking about just swapping out the cap and rotor instead of buying a new dizzy. Should I also change out the ignition coil assembly? The last part I'm looking at is the igniter unit assembly, but it's around $180 for just that. If my igniter assembly was bad would that cause my car not to run at all due to no spark?
Also my current dizzy is from a 95 GSR. Can I get a cap, rotor and ignition coil assy out of a Del Sol VTEC? the Honda dealership is closer then the Acura dealer, so I'd rather go to them first.
Old Aug 18, 2005 | 07:32 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">Should I also change out the ignition coil assembly?</TD></TR></TABLE>
If you've got one that you know is working, it can't hurt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">If my igniter assembly was bad would that cause my car not to run at all due to no spark?</TD></TR></TABLE>
Yep! Swapping for a known good ignitor is the best way to test it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">Can I get a cap, rotor and ignition coil assy out of a Del Sol VTEC? </TD></TR></TABLE>
I'm going to go with maybe. While the entire distributors themselves are interchangable, there are sometimes differences that keep you from using different caps or rotors on them. I've seen some different coils as well. Ignitors are usually all the same. Compare the parts before you commit to anything.
JerseySiPOS
Apr 29, 2011 07:20 AM
Stoich
Feb 20, 2006 12:33 PM
Tealeg88
Jan 16, 2006 11:08 AM
5lugcivic
Mar 28, 2005 10:40 AM
