Vehicle Speed Sensor
Old Aug 19, 2005 | 08:36 AM
themorphious's Avatar
Default Vehicle Speed Sensor
I own a 1994 Honda Civic EX 2 door Coupe, D16Z6. I need to know where the VSS (vehicle speed sensor) is located, and also where the tach gets it's signal. Any help would be greatly appreciated.
Old Aug 19, 2005 | 09:14 AM
Default Re: Vehicle Speed Sensor (themorphious)
anyone?
Old Aug 19, 2005 | 09:54 AM
ALLMOTA92EG's Avatar
The vss is located on the top of the tranny.
Old Aug 19, 2005 | 11:19 AM
lojackgsr's Avatar
Ya its on top of the tranny, look for something eletrical plugged in, I think its held in by 2 10MM's, the tach gets its signal from the vss also I believe.
Old Aug 19, 2005 | 11:52 AM
BenzTek134's Avatar
Default Re: (btownSI)
i think the connector is blue. i might be wrong but i think so.. might be black by now if car is older
Old Aug 19, 2005 | 08:33 PM
so, another question, if the speed sensor is reading correctly, then shouldnt the rpm's be correct too.....? if they are in the same sensor, then why are the rpms incorrect when the speed is correct?
Old Aug 22, 2005 | 10:21 AM
JimBlake's Avatar
Default Re: (themorphious)
I don't have a '94, but I really doubt the tach gets it's signal from the VSS. Think about it... How would the tranny 'know' what rpm you're at??
On my '95 Integra the tach got it's signal from the ignitor (blue wire from distributor).
Old Aug 22, 2005 | 10:22 AM
doublejz's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">tach got it's signal from the ignitor (blue wire from distributor).
Old Aug 22, 2005 | 12:57 PM
so, three more questions, what color is the wire leading to the gauge cluster for RPM's in the dash, and also, what wire is used for the computer to read RPM's? blue wire too, right? and one more, what color is the wire leading into the ecu for RPM's?
Old Aug 22, 2005 | 01:29 PM
JimBlake's Avatar
On my '95 it's like this...
CKP, CYP, & TDC sensors (in distributor) provide their signals TO the ECU.
ECU creates a trigger signal, telling the ignitor when to fire the coil.
Ignitor fires the coil AND produces a tach signal on the blue wire.
Blue wire goes to tachometer, cruise, & diagnostic port. Not back to ECU.
fcm
Nov 4, 2014 05:32 PM
LOVEthatDC2
Nov 19, 2009 10:02 PM
civic08
Feb 28, 2008 09:22 PM
SpoolinEK
16
Mar 25, 2005 08:34 PM
WAFFLES
Feb 20, 2002 04:19 PM
