check engine light (code 41)????
Old Mar 25, 2003 | 05:59 PM
JSJ EG6's Avatar
Default check engine light (code 41)????
whats code 41?????anyplace on the net where they say all the codes?btw its a 92 hatch si stock d16z6 it happend after i installed my dc header.i had to extend the wires.is there such a thing obd 1 o2 sensors and obd 2 sensors?
Old Mar 25, 2003 | 06:02 PM
TimoneX's Avatar
New User
Default Re: check engine light (code 41)???? (TEAM JSJ)
My book's out in the garage but as I recall that's an O2 sensor heater circuit code.
Old Mar 25, 2003 | 07:02 PM
Chiovnidca's Avatar
Default Re: check engine light (TimoneX)
Yea, o2 heater code. Measure the resistance of the heater between the two black wires. It should be between 4-10 ohms if I remember right.
Old Mar 25, 2003 | 07:42 PM
JSJ EG6's Avatar
Default Re: check engine light (TurboD16Chiovnidca)
what do you mean?how can i fix it or do i have to bring my car to honda????
Old Mar 25, 2003 | 08:05 PM
Chiovnidca's Avatar
Default Re: check engine light (TEAM JSJ)
If you want to be sure what the problem is, measure the resistance of the o2 heater to see if it's good or bad. And go from there.
Old Mar 26, 2003 | 03:29 AM
Chiovnidca's Avatar
Have you checked your wire extensions? Sorry,I missed that part of your post the first time.
Old Apr 3, 2003 | 09:11 PM
EG6owner-T's Avatar
41 Primary Heated O2 sensor heater circuit Open or short in Primary O2 sensor heater circuit, defective Primary O2 sensor heater circuit
i have this same problem, but cx didnt come with 4 wire O2 sensor and i have a one wire for now, can anyone input some suggestions?
im goin turbo soon, so get a wideband one?
thanks.
Spug
May 26, 2012 12:15 AM
spencedogg
12
Nov 30, 2003 11:57 AM
94civic2nv
Oct 6, 2003 04:00 PM
bumpin_bass
Dec 30, 2002 05:53 PM
