ignition boxes?
Old Mar 26, 2003 | 10:23 AM
civic ex si's Avatar
Default ignition boxes?
is there anything you have to do special to anything if i got an ignition box? are they easy to put in? is there anything i should know about one or what to do to make it work correctly?
Old Mar 26, 2003 | 02:57 PM
19924ws's Avatar
Default Re: ignition boxes? (civic ex si)
Not really, there are no internal mods or welding. Any wire cutting and splicing is covered in the directions of the ignition. I've had both an MSD and a Jacobs iCE Pak. The Jacobs is a whole bunch easier to install and didn't require any wire cutting, but you do have to run a wire through the firewall. The MSD required wire cutting and splicing making it a little harder to put in. All the wiring diagrams were in the instrutions. The Jacobs also has 3 parts and the MSD has 1 or 2 if you get the MSD coil. I have pics of how I mounted the MSD here:
http://www.imagestation.com/album/?id=4290715273
Having had both I'd recommend the Jacobs for the novice and the MSD for someone has minimal experience. The MSD is about 160 and 35 for the coil and the Jacobs was 325, but has a coil included. Mike
B18cFreak
Jul 30, 2008 01:26 PM
r1ch1e
Aug 30, 2007 11:12 AM
swapped95
12
Dec 29, 2006 12:38 PM
dc4teg95
Nov 21, 2006 02:08 PM
BLKCRX
Nov 15, 2002 10:04 AM
