obd2 to obd1
Old Mar 26, 2003 | 08:38 PM
syndicate43's Avatar
Default obd2 to obd1
I am about to put a 98 jap spec itr motor in my 92 civic what will I need to do this I have already ordred a obd1 ecu I assume that I will need to get a obd1 engine wiring harness is there any thing else I will need to get to install this in my car
any help would be great
thanks
Old Mar 26, 2003 | 08:58 PM
andrewasf77's Avatar
Default Re: obd2 to obd1 (syndicate43)
did you try searching, i really dont know much about the wiring of a jdm motor, but searching would probably help you out
Old Mar 26, 2003 | 11:13 PM
RangerDan's Avatar
thanks
O.K. Which model civic do you have? It may not matter on that year however. There should be vtec wired allready.
Your car is a obd1 so you wont need a harness.
What ecu do you have specifically? p28 p30?
Best to do a search and get familar with what youre doing and if nothing else you will gain knowledge in the world of swaps.
Me learning also...
Old Mar 26, 2003 | 11:29 PM
Default Re: obd2 to obd1 (RangerDan)
I am getting a p28 ecu with the jum program I have a dx model.
I have done many swaps just never jdm motors or anything that was obd2.
I have done a search on this and I havent found anything usefull.
I know that the wiring harness on the jdm motors is switched or opposite of the usdm because of the right hand drive.
My question is do the jap spec cars use obd1 or obd2 computer systems
Thanks
Old Mar 26, 2003 | 11:57 PM
RangerDan's Avatar
Good ecu and chip.
Same here. Actually only a couple other swaps but my first jdm swap. ITR into 93 Si.
It happens.
Dont matter. Your p28 will plug into youre existing harness. Your Dx is wired for vtec. Although you will have to add 2 wires for vtec on the motor side.
JDM motors have different computers for different years in your case the ecu that came with that motor is either a p72 or p73 both are obd2.
Normally the p28 is for sohc vtec motors but with a jun chip ( Im guessing its chipped for a b motor.) will make the p28 ready for a B motor.
When you do the swap you can plug the ecu in as is the only thing you wont get is vtec until you route that wiring.
Old Mar 29, 2003 | 11:49 AM
domesticabuzer's Avatar
jdmek(98)
Dec 1, 2009 02:36 PM
ELIT3
Aug 6, 2009 02:55 PM
Cain Marko
Jul 7, 2004 02:40 PM
Glen Tennis
Dec 17, 2003 06:06 AM
TKL
May 27, 2003 07:57 PM
