agh, stupid stupid I must be?
Old Mar 26, 2003 | 05:08 AM
MysteryWagon's Avatar
Default agh, stupid stupid I must be?
i woke up in a hury, let the car warm up, and left my friends house. As i was driving, the guy behind me was riding my ***, so I got on it in 2nd. As i went through neutral slowly the rpm never came back down and contuined to bounce off the redline. I shut the car down and coast it down to a parking lot. What in the world would cause this.
-when i start car it heads for redline
-the throttle cable is fine
-what could the problem be?
-since i was tired I called a friend not thinking about much
Could the throttle have stayed open while throttle cable is still in normal position.
please help, i would like to fix car without having to tow, I have no money.
B16a1 in 90 hatch
thanks alot Justin
Old Mar 26, 2003 | 05:32 AM
Default Re: agh, stupid stupid I must be? (MysteryWagon)
bump please
Old Mar 26, 2003 | 05:52 AM
CRX Si's Avatar
check the butterfly on the TB... it may be stuck open when the cable itself is fine...
Old Mar 26, 2003 | 05:58 AM
bryan305's Avatar
Default Re: agh, stupid stupid I must be? (CRX Si)
that was my thought....get some carb cleaner and spray it in there...
Old Mar 26, 2003 | 07:22 AM
Blaze45's Avatar
Brrraaaap!
Default Re: agh, stupid stupid I must be? (bryan305)
does it run ok now? any other problems that you have had lately?
Blaze
Old Mar 26, 2003 | 07:40 AM
94TealGSR's Avatar
Good advice. A lot of things could cause your problem, but the butterfly seems to be the most likely cause.
Old Mar 26, 2003 | 07:43 AM
IN VTEC's Avatar
Default Re: agh, stupid stupid I must be? (94TealGSR)
you can also check your tps voltage to verify even if the throttle plate is in the right position.
Old Mar 26, 2003 | 11:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: agh, stupid stupid I must be? (IN VTEC)
i know this sounds obvious, but the floormat could be the culprit.
nuked a 5.0 that way, actually shortened 3 pushrods.
Old Mar 26, 2003 | 11:39 AM
Default Re: agh, stupid stupid I must be? (boostedcivicsir)
car is fixed, like i said i am stupid, my JG VictorX mani lost a maifold plug the great big one on the right side making a huge leak causing high rpm. It is was not tight enough and it vibrated out i guess.
the thing that sucks is, not only does my car feel slugicious which might mean that i hurt something in the head. but my friend that was running me around to get parts totaled his car following me to his house.
Justin
Old Mar 27, 2003 | 07:25 PM
jwaked's Avatar
Shoot, you must be kind of sad for him. That sucks.
Jay
Old Mar 27, 2003 | 09:37 PM
ThrillaKilla's Avatar
my friend had a similar problem with his crx dohc ZC... those damn aftermarket pedal screws would stick into the floormat... his tb butterfly would also get stuck as a result of not greasing it time to time... *didnt know you had to grease them but hey its metal, and i guess the throttle was wide open so much ( ) it just ended up sticking there after a while...
StayKrafty
11
Nov 6, 2022 01:50 PM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
Mr. Em1
Apr 21, 2007 08:23 AM
mixmastabob
Aug 1, 2003 11:09 PM
SeaBass
10
May 17, 2003 12:16 PM
