do u need a different shim to put a type r lsd in a gsr???
Old Mar 26, 2003 | 08:07 AM
lowcivex's Avatar
Default do u need a different shim to put a type r lsd in a gsr???
like the title says??
I hope someone can help before i rip the tranny apart
thanks
Old Mar 26, 2003 | 09:23 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: do u need a different shim to put a type r lsd in a gsr??? (lowcivex)
the gsr and type r carriers are different, and i know the bearing thicknesses are different. 0.050 on each side. i will tell you this you cant use gsr bearings in an si trans. as far as needing a shim i would think you will. in the helms maunal it should tell you where and how much clearance you should have.
Old Mar 26, 2003 | 11:14 AM
PupaScoopa's Avatar
Default Re: do u need a different shim to put a type r lsd in a gsr??? (boostedcivicsir)
I'm going to do the ITR LSD into my Si swap with weekend. I orderd all the 80mm shims just to be on the safe side.
Old Mar 26, 2003 | 11:22 AM
Mr. Badwrench
Default Re: do u need a different shim to put a type r lsd in a gsr??? (PupaScoopa)
ITR shouldnt matter. i know for a fact the ring gear is different betwee the gsr and si. same teeth but different inner diameter. and the bearings i know for a fact are 0.050 thicker 0.100 total.
Old Mar 26, 2003 | 11:50 AM
Muad'Dib's Avatar
Corr Performance Pilot
yeah... you'll need some shims cause all the tolarances are different. Check your Helms manual for the listing of the shims that you might need. HTH.
samuraijackass
Transmission & Drivetrain
22
Feb 21, 2011 09:15 PM
mike1114
Mar 26, 2005 06:47 PM
Ls1 FD3s
Feb 26, 2005 10:22 AM
glagola1
Apr 23, 2004 09:11 PM
CrxSi10
Mar 7, 2003 09:58 PM
